port-channel strange issue
James Lasky
I've a port-channel (no LACP) config in this way on my 6509:
interface Port-channel11
description  Te1/8,2/8
switchport
switchport trunk allowed vlan 1-3996,3999-4094
switchport mode trunk
logging event link-status
logging event trunk-status
load-interval 30
end
I see the "Age of the port in the current state" of the second ten-giga link that seems up by few minutes...
#sh etherchannel 11 detail
Group state = L2
Ports: 2   Maxports = 8
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Te1/8
Port state    = Up Mstr In-Bndl
Channel group = 11          Mode = On      Gcchange = -
Port-channel  = Po11        GC   =   -         Pseudo port-channel = Po11
Port index    = 1           Load = 0x55        Protocol =    -
Age of the port in the current state: 202d:00h:21m:34s
Port: Te2/8
Port index    = 0           Load = 0xAA        Protocol =    -
Age of the port in the current state: 0d:00h:03m:50s
                Port-channels in the group:
Port-channel: Po11
Age of the Port-channel   = 763d:05h:37m:56s
Logical slot/port   = 14/3          Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Fast-switchover     = disabled
Load share deferral = disabled
Ports in the Port-channel:
Index   Load      Port          EC state       No of bits
1      55          Te1/8                 On   4
0      AA          Te2/8                 On   4
Time since last port bundled:    561d:05h:17m:53s    Te1/8
Time since last port Un-bundled: 561d:05h:33m:21s    Te1/8
Last applied Hash Distribution Algorithm: Fixed
The problem is that it doesn't refresh that timer...
If I repeat the command after seconds, minutes, or days it remains the same, the only counter incrementing is for the bundle...
Any idea why ?
could it be a problem ?
On the opposite site of the port-channel the counter is about hundreds of days...
Tks
Group state = L2
Protocol:    -
Minimum Links: 0
                Ports in the group:
Port: Te1/8
Port: Te2/8
Port-channel: Po11
Age of the Port-channel   = 763d:05h:38m:17s
Protocol            =    -
1      55          Te1/8                 On   4
0      AA          Te2/8                 On   4
Time since last port bundled:    561d:05h:18m:13s    Te1/8
Time since last port Un-bundled: 561d:05h:33m:41s    Te1/8
James Lasky
Just to update the community.
The problem is due to CSCua65390
