Very low connection speed with Cisco 1801
merlin956
This is my first attempt at configuring an 1801 and I am getting extreamly low bandwidth.
Tests show up/down speeds on aroung 100kbps.  I can't see any reason with the possible exception of the show dsl capacity values which never seem to change.
I am hopeing that someone here will be able to point out my config error.
wan#show ver
Cisco IOS Software, C180X Software (C180X-ADVENTERPRISEK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:13 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH13, RELEASE SOFTWARE (fc1)
wan uptime is 7 hours, 46 minutes
System returned to ROM by reload at 00:11:15 AEST Wed Oct 10 2012
System image file is "flash:c180x-adventerprisek9-mz.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1801 (MPC8500) processor (revision 0x400) with 236544K/25600K bytes of memory.
Processor board ID xxxxxxxxxxx, with hardware revision 0000
9 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
1 Virtual Private Network (VPN) Module
63808K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*0        CISCO1801             xxxxxxxxxxx
wan#show run
Building configuration...
Current configuration : 6939 bytes
! Last configuration change at 07:18:13 AEST Wed Oct 10 2012 by xxxx
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname wan
boot-start-marker
boot system flash c180x-adventerprisek9-mz.151-4.M4.bin
boot-end-marker
security authentication failure rate 3 log
logging buffered 51200 warnings
no aaa new-model
clock timezone AEST 10 0
crypto pki trustpoint TP-self-signed-2897494766
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2897494766
revocation-check none
rsakeypair TP-self-signed-2897494766
dot11 syslog
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.150.128 192.168.150.254
ip dhcp excluded-address 192.168.150.1 192.168.150.32
ip dhcp pool internal-net
import all
network 192.168.150.0 255.255.255.0
default-router 192.168.150.254
domain-name xxxxxxxxxxxxxx.com.au
dns-server 192.168.150.1
lease 7
ip dhcp pool static-pool
import all
origin file flash://static-bindings
ip cef
ip flow-cache timeout active 5
ip domain name xxxxxxxxxxxxxx.com.au
ip name-server 130.139.4.4
ip name-server 211.29.132.12
no ipv6 cef
license udi pid CISCO1801 sn xxxxxxxxxxx
archive
log config
  hidekeys
username xxxx privilege 15 password 7 xxxxxxxxxxxxxxxxxxxxxx
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
ip ssh pubkey-chain
  username xxxx
   key-hash ssh-rsa xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxx@xxxxxxxx
  quit
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key pacxxxxxxipsecvpntunnel address xx.xxx.xxx.xx
crypto isakmp keepalive 360
crypto ipsec transform-set pacxxxxxxipsec esp-3des esp-sha-hmac
crypto map pacxxxxxx 10 ipsec-isakmp
! Incomplete
description Tunnel to xx.xxx.xxx.xx
set peer xx.xxx.xxx.xx
set transform-set pacxxxxxxipsec
match address IPSEC
interface Tunnel1
description IPSEC TO xxxxxx
ip address 192.168.149.5 255.255.255.252
ip mtu 576
shutdown
tunnel source Dialer1
tunnel destination xx.xxx.xxx.xx
tunnel path-mtu-discovery
interface ATM0
no ip address
no ip route-cache
load-interval 30
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address 192.168.100.199 255.255.255.0
duplex auto
speed auto
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
interface Vlan1
description vlanSW
ip address 192.168.150.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
ppp chap hostname xxxxxxxxxxxxxxx@xxxxxxxx.com.au
ppp chap password 7 xxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxx@xxxxxxxx.com.au password 7 xxxxxxxxxxxxxxxxxx
no cdp enable
interface Dialer1
no ip address
router bgp 65534
bgp always-compare-med
bgp log-neighbor-changes
bgp bestpath med confed
neighbor 192.168.100.254 remote-as 65531
neighbor 192.168.100.254 prefix-list BGP-IMPORT in
neighbor 192.168.100.254 prefix-list BGP-EXPORT out
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-export version 5
ip flow-export destination 192.168.150.1 23456
ip dns server
ip dns spoofing
ip nat inside source list 23 interface Dialer0 overload
ip nat inside source static tcp 192.168.150.1 22 interface Dialer0 1000
ip nat inside source static udp 192.168.150.1 22 interface Dialer0 1000
ip nat inside source static tcp 192.168.150.1 25 interface Dialer0 25
ip nat inside source static tcp 192.168.150.1 53 interface Dialer0 53
ip nat inside source static udp 192.168.150.1 53 interface Dialer0 53
ip nat inside source static tcp 192.168.150.2 80 interface Dialer0 80
ip nat inside source static tcp 192.168.150.1 110 interface Dialer0 110
ip nat inside source static udp 192.168.150.1 110 interface Dialer0 110
ip nat inside source static tcp 192.168.150.1 143 interface Dialer0 143
ip nat inside source static udp 192.168.150.1 143 interface Dialer0 143
ip nat inside source static tcp 192.168.150.1 465 interface Dialer0 465
ip nat inside source static tcp 192.168.150.1 993 interface Dialer0 993
ip nat inside source static udp 192.168.150.1 993 interface Dialer0 993
ip nat inside source static tcp 192.168.150.1 995 interface Dialer0 995
ip nat inside source static udp 192.168.150.1 995 interface Dialer0 995
ip nat inside source static tcp 192.168.150.2 3389 interface Dialer0 3389
ip nat inside source static udp 192.168.150.2 3389 interface Dialer0 3389
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended IPSEC
ip prefix-list BGP-EXPORT seq 10 permit 192.168.150.0/24 le 32
ip prefix-list BGP-EXPORT seq 99 deny 0.0.0.0/0
ip prefix-list BGP-IMPORT seq 10 deny 192.168.150.0/24 le 32
ip prefix-list BGP-IMPORT seq 20 permit 192.168.0.0/16 le 32
ip prefix-list BGP-IMPORT seq 25 permit 172.16.0.0/12 le 32
ip prefix-list BGP-IMPORT seq 30 permit 10.0.0.0/8 le 32
ip prefix-list BGP-IMPORT seq 98 deny 0.0.0.0/0 ge 25
ip prefix-list BGP-IMPORT seq 99 deny 0.0.0.0/0 le 24
access-list 23 permit 192.168.150.0 0.0.0.255
access-list 99 permit 192.168.101.1
access-list 99 permit 192.168.100.1
access-list 99 permit xx.xxx.xxx.xx
access-list 99 permit 192.168.150.1
access-list 101 permit tcp xx.xxx.xxx.x 0.0.0.255 any eq 3389
access-list 101 permit udp xx.xxx.xxx.x 0.0.0.255 any eq 3389
access-list 101 permit tcp xxx.xxx.xxx.x 0.0.0.255 any eq 3389
access-list 101 permit udp xxx.xxx.xxx.x 0.0.0.255 any eq 3389
access-list 101 deny   tcp any any eq 3389
access-list 101 deny   udp any any eq 3389
access-list 101 permit ip any any
no cdp run
snmp-server community xxxxxxxxxxxx RO 99
snmp-server ifindex persist
snmp-server location Brisbane, Australia
snmp-server contact Network Operations (noc@xxxxxxxxxxxxxx.com.au)
snmp-server chassis-id Border Router
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
session-timeout 35791  output
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
wan#show int atm 0
ATM0 is up, line protocol is up
  Hardware is MPC ATMSAR (with Alcatel ADSL Module), address is 4055.39a2.2360 (bia 4055.39a2.2360)
  MTU 4470 bytes, sub MTU 4470, BW 814 Kbit/sec, DLY 450 usec,
     reliability 255/255, txload 63/255, rxload 2/255
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  23 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input never, output 00:00:00, output hang never
  Queueing strategy: Per VC Queueing
  30 second input rate 7000 bits/sec, 15 packets/sec
  30 second output rate 203000 bits/sec, 20 packets/sec
     158384 packets input, 40217824 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     171686 packets output, 127415558 bytes, 0 underruns
     0 unknown protocol drops
wan#show dsl int atm 0
ATM0
Alcatel 20190 chipset information
         ATU-R (DS)            ATU-C (US)
Modem Status:     Showtime (DMTDSL_SHOWTIME)
DSL Mode:     ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:      0x03                 0x2
Chip Vendor ID:     'STMI'                 'IFTN'
Chip Vendor Specific:  0x0000             0x71BE
Chip Vendor Country:   0x0F             0xB5
Modem Vendor ID: 'CSCO'                 '    '
Modem Vendor Specific: 0x0000             0x0000
Modem Vendor Country:  0xB5             0x00
Serial Number Near:    FGL151528D 1801
Serial Number Far:
ModemChip ID:      C196 (3)
DFE BOM:     DFE3.0 Annex A (1)
Capacity Used:     100%                 73%
Noise Margin:     12.0 dB             21.5 dB
Output Power:     18.5 dBm             12.5 dBm
Attenuation:     23.0 dB              9.0 dB
FEC ES Errors:      0                 212
ES Errors:      0                 30
SES Errors:      0                  1
LOSES Errors:      0                  1
UES Errors:      0                  0
Defect Status:     None                            None
Last Fail Code:     None
Watchdog Counter: 0x44
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:     15011 (0 spurious)
PHY Access Err:     0
Activations:     1
LED Status:     ON
LED On Time:     100
LED Off Time:     100
Init FW:     init_AMR-4.0.015_no_bist.bin
Operation FW:     AMR-4.0.015.bin
FW Source:     embedded
FW Version:     4.0.15
          DS Channel1      DS Channel0    US Channel1      US Channel0
Speed (kbps):              0           18257             0             814
DS User cells:              0          955591
US User & Idle cells:                          0        53687931
Reed-Solomon EC:          0             469             0            5824
CRC Errors:              0              40             0              40
Header Errors:              0              34             0             271
Total BER:          0E-0         5670E-11
Leakage Average BER:      0E-0         1254E-10
Bitswap:               enabled          enabled
LOM Monitoring : Disabled
DMT Bits Per Bin
Not able to get complete DMT bin information.Retry "show dsl" after few seconds.
DSL: Training log buffer capability is not enabled
I have noted that every time I do a "show dsl int atm 0" the "Capacity Used" is always 100% and 73% whereas txload and rxload from "show int atm 0" do vary.
paolo bevilacqua
Capacity is a static value so it's normal that never changes.
Config is basically correct, It seems very strange you''ve got such a low speed, have you tried with another router for comparison?
paolo bevilacqua
Very red faced!
It seems that the same day I swapped in the cisco router the ISP bandwidth limited the account.  The router config works fine now that is fixed.
Thanks for looking at it and sorry to trouble you over nothing.
Not embarassing at all.
Thank you for the nice rating and good luck!
