Which physical ATM link it takes?
frank.lu
Here is the PNNI topology from one of the ASP:
USKEN15DRASP#sh atm pnni topology node 13
Node 13 (name: USUNI13DRASP, type: LS1015, ios-version: 12.0)
Node ID..: 56:160:47.009181000000009086003401.009086003401.00
Node AESA: 47.009181000000009086003401.009086003401.01
Leadership Priority: 0, Claims PGL: No, Transit Calls: Allowed
Ancestor: No, Nodal Representation: Simple, Connected: Yes
More P2MP Branch Points: Yes, Non-Transit For PGL Election: No
status link type local port remote port neighbor
up hrz ATM12/0/1 ATM12/0/1 USUNI01DRASP
up hrz ATM12/1/0 ATM12/1/0 USSPR011RASP1
up hrz ATM12/1/1 ATM12/1/0 USCRN012RASP2
USKEN15DRASP#
There are 3 physical links from USUNI13DRASP to USKEN15DRASP, how can I find out which physical ATM link it takes from USUNI13DRASP to USKEN15DRASP?
frank.lu
OK... I need to enable the Background Routes in order to see the physical link it takes, but after I setup the Link Selection, it is still showing the alternate link as first choose as following, what did I do wrong?
USUNI13DRASP#sh run int atm 12/1/0
Building configuration...
Current configuration:
interface ATM12/1/0
description DS-3 to Springfield Main Comm room 1
no ip address
no ip directed-broadcast
logging event subif-link-status
no atm ilmi-keepalive
atm pnni link-selection cbr alternate
atm pnni link-selection vbr-rt alternate
atm pnni link-selection vbr-nrt alternate
atm pnni link-selection abr alternate
atm pnni link-selection ubr alternate
end
USUNI13DRASP#
USUNI13DRASP#sh atm pnni background routes 12
Background Routes From CBR/AW Table
3 Routes To Node 12
1. Hops 3. 1:ATM12/1/0 -> 15:ATM12/0/2 -> 14:ATM12/1/0 -> 12
->: aw 15120 cdv 414 ctd 504 acr 42498 clr0 10 clr01 10
<-: aw 15120 cdv 414 ctd 504 acr 42498 clr0 10 clr01 10
2. Hops 3. 1:ATM12/0/1 -> 13:ATM12/0/2 -> 11:ATM1/0/1 -> 12
->: aw 15120 cdv 414 ctd 462 acr 147743 clr0 10 clr01 10
<-: aw 15120 cdv 414 ctd 462 acr 147743 clr0 10 clr01 10
3. Hops 3. 1:ATM12/0/1 -> 13:ATM12/0/2 -> 11:ATM0/1/0 -> 12
Background Routes From CBR/CDV Table
3 Routes To Node 12
