Port forward CISCO2901/K9
Hello
I have a finger print machine, I want to connect it through internet remotely so I must make port forwarding in the router which is CISCO2901/K9, I did but it will not be opened still by checking in this website(https://ping.eu/port-chk/) by using the the public IP and the port.
please someone check the configuration attached to see what is wrong?
Best Regrds
 The NAT you setup will work fine for connection from the inside network to the outside. But, if I understood it correctly you want the opposite.
 Take a look on this link
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13770-1.html
access-list 100 permit ip 192.168.xx.xx 0.0.0.xx any <<- this IPsec ACL effect the NATing can you change any to remote LAN subnet
@MHM Cisco World
Thanks for reply.
I dont have enough expreince please let me what should I write,remove or Change?
please answer me with comands
sure
what is your local and remote LAN subnet ?
