Port Forward down through Layer 3 Switch ???
keithatwood
I'm looking at implementing a cisco 3550 Layer 3 switch and would like to know if i can forward ports down to all of my differnt Subnet Servers/Pc's.
For example. See attached image.
10.0.3.5 is a mail server. 4.2.2.2 is our public IP.
I would like to forward TCP port 25 down to our Mail servers IP.
Does anyone know of a reason this will not work by using the cisco 3550? Currently we have a flat network (1 subnet) and port forwarding works fine.
Thanks!
Reza Sharifi
It should work fine. If you have EMI version of the IOS, you can do a full later-3 routing.  Since the network is not very big, I am assuming you are going to run static routes and SMI version of the software should work just fine for you.You need to create 4 SVIs on the 3550 (one for each subnet). The connection between the 3550 and the router can be a /30. /24 works fine too, but it doesn have to be.
Good Luck
Reza
Thanks very much!
Yes it is a small network and the 3550 is using SMI.
By SVI for each subnet, I'm assuming you mean add the following command:
Switch(config)#
interface Vlan2
Switch(config-if)#
ip address 10.0.2.1 255.255.255.0
Switch(config-if)#
no shutdown
And so on for Vlan 3,4,5 etc.
Then
Switch(config)#
ip routing
Correct ?
Thanks again!
Yes, that is correct, one SVI for each subnet.  Don't forget to create the layer-2 vlan for each switch and add the proper interfaces to that vlan.
layer-3 vlan or SVI
Switch(config-if)#
Switch(config-if)#
no shutdown
Switch(config-if)#
ip address 10.0.3.1 255.255.255.0
Switch(config-if)#
no shutdown
Layer-2 vlan
vlan 2
name test2
vlan 3
name test3
and so on.
Reza
