Port Forwarding (access-list)
Erik Hennerfors
I'm having problem adding access to a NAS inside my network and I can't seem to understand why.
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 103 interface GigabitEthernet0/0 overload
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 1 permit 10.0.3.0 0.0.0.255
access-list 1 permit 10.0.4.0 0.0.0.255
access-list 103 permit tcp any host 10.0.3.3 eq 445
the 103 access-list is the one I can't seem to get working, I'm not quite sure if I got the access-list functionality right but I wan't to forward traffic on the external WAN interface (GigabitEthernet0/0) on port 445 (SMB) to the server that act as a NAS (10.0.3.3).
What is woring with my configuration in the top of this post?
Many regards
Erik
23 Replies 23
Erik Hennerfors
I'll try to respond to all tip.
I'm able to telnet the port from the inside (from the nas) but not from the outside (445). The interface GigabitEthernet0/0 is obtaining ip address from a DHCP (ip address dhcp).
I'm able to access the nas from all of my internal subnets by pinging and adding the shares on diferent devices on the diferent subnets.
And the static IP-address configuration on the server looks good. (tripple checked it).
Thanks for al tips.
Still you haven’t confirm about the Nat translation asked by Blau
Do you see NAT translation on router when you try to access NAS from internet?
show ip nat translation
Also from router are you able to do telnet.
gimli#telnet 10.0.3.3 445
Also make sure when you’re accessing that sever from outside/Internet use Ip address which is assigned via DHCP .
Ah sorry missed that part, I'm able to telnet the server on port 445 from the router:
Trying 10.0.3.3, 445 ... Open
There seems to be no connection in nat trans, but the remote desktop service can be used (3389).
gimli#sh ip nat tran | include 10.0.3.3
tcp 78.*.*.*:162     10.0.3.3:161          ---                   ---
tcp 78.*.*.*:445     10.0.3.3:445          ---                   ---
udp 78.*.*.*:445     10.0.3.3:445          ---                   ---
tcp 78.*.*.*:3389    10.0.3.3:3389         ---                   ---
udp 78.*.*.*:64206   10.0.3.3:64206        94.245.121.251:3544   94.245.121.251:3544
Hello Erik,
Can you try telnet port from some internet server and then check nat translation?
server> telnet 78.X.X.X 445
Also can you provide routing table of NAS server?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Nothing elese then the nat translations that are there before I make a connection atempt and the atempt times out "
telnet: Unable to connect to remote host: Connection timed out"
OK, I assume that your WAN port configuration did not change.
 ip ddns update hostname *.se
 ip ddns update dyndns
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
 no mop enabled
We will create test ACL to verify that packets are received by your router.
ip access-list extended test
permit tcp any host YOUR-CURRENT-PUBLIC-IP eq 445
permit ip any any
int Gi0/0
ip access-group test in
Now can you telnet on port from public server again and verify that packets arrived to your router?
gimli#sh ip access test
Best Regards
I've tested all sugested propositions but with no success, I've tried another "cheep" router with success so there have to be something I'm missing in the Cisco 1912 Router.
I can't see any connection from aserver located at another location to the router using "sh ip nat tran | include ".
Anyone with any more ideas?
So I called our ISP and they went trough my connection and it seeams that they've been blocking 445 the whole time even tough I called them 5 times allready asking the same questions.
Thanks for all replys and sorry for the mess made by my ISP.
Erkut Oztekin
hi eric i have the same problem did solutions?
