Port Forwarding (access-list)
Erik Hennerfors
I'm having problem adding access to a NAS inside my network and I can't seem to understand why.
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 103 interface GigabitEthernet0/0 overload
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 1 permit 10.0.3.0 0.0.0.255
access-list 1 permit 10.0.4.0 0.0.0.255
access-list 103 permit tcp any host 10.0.3.3 eq 445
the 103 access-list is the one I can't seem to get working, I'm not quite sure if I got the access-list functionality right but I wan't to forward traffic on the external WAN interface (GigabitEthernet0/0) on port 445 (SMB) to the server that act as a NAS (10.0.3.3).
What is woring with my configuration in the top of this post?
Many regards
Erik
23 Replies 23
blau grana
Level 7
Level 7
You need to actually configure port forward on your router.
ip nat inside source static 10.0.3.3 445 interface Gi0/0 445
delete this line and ACL 103, it is not necessary:
no ip nat inside source list 103 interface GigabitEthernet0/0 overload
no access-list 103 permit tcp any host 10.0.3.3 eq 445
Try this, if you have some inbound ACL on Gi0/0 interface, you have add line to permit traffic toward your NAS.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Thank you for your reply, I've added:
ip nat inside source static tcp 10.0.3.3 445 interface GigabitEthernet0/0 445
But can't connect, it just times out. I can access the NAS from inside the network but not from the outside.
Any ideas why?
Is it possible to upload entire config of your router?
You can erase keys, passwords and substitute public IPs with some other, but be sure that public IPs will be substituted with some other IPs 1:1.
Best Regards
Yes ofcourse, here is the entire config:
http://pastie.org/7999546
Your router config is correct, you should verify the server for firewall or default gw problem.
Alain
Thanks for your time, I'll look into our firewall and see if there is something there
Erik, one thing I find useful when working on these kind of things it an open port checker (just google "open port checker"). These are websites which will probe your router address to see if the port is reachable from the internet. If you do this and it fails you know there is definitely a firewall issue. You don't say anything about your WAN connectivity but if this a standard DSL type service providers will sometimes block inbound access.
You could also have done a Port scan on the networks to determine which ports are open and closed.
I can't get this to work, I've added the port used for RDP and that works, but not the SMB. I've tried a portscanner which says that the port was blocket (used http://www.whatsmyip.org/port-scanner/).
I allso disabled the firewall on the server but with no effect.
Any ideas?
As Alain wrote, router config looks good, there has to be problem with your NAS.
Your NAS is on subnet 10.0.3.0/24 can you access it from different subnet, or just same subnet. Maybe default gateway is not properly configured.
Also doublecheck if:
- IP/ports are correct, some typo could be in configuration
- do you see NAT translation on router when you try to access NAS from internet #show ip nat translation
- check GW on NAS, try ping some device on different subnet/internet
Best Regards
Configuration shared by you in that I am not seeing any default route towards ISP.
I think default route is obtained via DHCP.
 ip address dhcp
Best Regards
Thanks Blau.
       Form that server 10.0.3.3 are you able to make self telnet on port number 445 ?.
Ravi Singh
Level 7
Level 7
First of all you should use static NAT because with dynamic NAT no one can make connection form outside untill unless Translation table is not created. It is created only when some one inititae the connection from inside. And you also have to check that you are able to telnet on the same port which you are using (i.e. 445) from outside.
