Cisco MGX 8850
kumarvin
I am facing the problem on One DS3 line configured on AXSM T3/E3 Card. On this line I am getting LOCD alarm state. Due to which one of the DS3 line is down
Can some please let me know what is LOCD Alarm and why/when this alarm occur and what is the resolution steps from same.
Thanks & Regards
Vinod.........
vmiller
Level 7
Level 7
LOCD: Loss of Cell Delineation
Loss of Cell Delineation (LOCD) is a SONET port status indicator that activates when an LOCD defect occurs and does not clear for an interval of time equal to the alarm integration period, which is typically 2.5 seconds
5 Replies 5
vmiller
Level 7
Level 7
hi vmiller thnks for replying but I also want to know how to rectify/resolve such alarm for smooth flow of the network.
Check the reference clock source. Compare
parameters between local and service provider end
or possibly a phsical layer problem.
thats the best i could find.
you could always open a case with the tac.
Hi vmiller,
Thanks for your support.......
How did you finally solve the problem.
We are also facing the same issue but on a E1 of AXSM-32-T1E1-E Card ?
