port forwarding and acces-list
eekie043nl
dear,
i can't seem to get port forwarding working on my cisco router.
i'm trying to forward the port 25565 from my server (local ip) to my public ip address. now i tried this with the command ip nat inside static tcp [local address] 25565 interface g0/0 25565 but doesnt seem to work.
can it be that my acces-list blocks this? or do i forget something?
my running-config:
ip nat inside source static udp 192.168.1.2 25565 interface GigabitEthernet0/0 25565
ip nat inside source static tcp 192.168.1.2 25565 interface GigabitEthernet0/0 25565
ip nat inside source route-map rm-nat interface GigabitEthernet0/0 overload
ip nat inside source route-map rm-nat-Miller interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 212.178.140.45
ip route 0.0.0.0 0.0.0.0 212.178.140.181
ip access-list standard acl-vty
 permit 57.66.108.39
 permit 80.101.152.38
 permit 31.171.201.96 0.0.0.31
 permit 192.168.1.224 0.0.0.31
ip access-list extended acl-nat
 permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended acl-nat-Miller
 permit ip 212.178.143.120 0.0.0.7 any
ipv6 route ::/0 2001:41F0:F300:5::1
route-map Mondi-guest permit 10
 match ip address 10
 set ip next-hop 212.178.140.45
route-map Miller-Graphics permit 10
 match ip address 20
 set ip next-hop 212.178.140.181
route-map rm-nat permit 10
 match ip address acl-nat
route-map rm-nat-Miller permit 20
 match ip address acl-nat-Miller
access-list 10 permit 192.168.1.0 0.0.0.255
Julio Garcia
did you try with the "extendable" option? Also, can you post the interfaces configuration as well?
Apart from that, the second route-map NAT looks strange, you are matching traffic from public IP addresses in the acl rm-nat-Miller
Julio
Julio Garcia
Julio
hi,
no i did not try the extendable option yet because the only thing i don't know about cisco is the whole acces-list thing.
interface configuration:
 description outside-ziggo
 ip address 212.178.140.46 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 ip policy route-map Mondi-guest
 duplex auto
 speed auto
 ipv6 address 2001:41F0:F300:5::2/64
 ipv6 enable
 no cdp enable
interface GigabitEthernet0/1
 description inside
 no ip address
 ip nbar protocol-discovery
 duplex auto
 speed auto
interface GigabitEthernet0/1.4
 description inside MondiGuest
 encapsulation dot1Q 4
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.50
 description inside Miller-Graphics
 encapsulation dot1Q 50
 ip address 212.178.143.121 255.255.255.248
 ip nat inside
 ip policy route-map Miller-Graphics
interface GigabitEthernet0/2
 description orange
 ip address 212.178.142.1 255.255.255.248
 duplex full
 speed 100
 description outside-ziggo-Miller
 ip address 212.178.140.182 255.255.255.252
 ip nat outside
 duplex auto
 speed auto
 no cdp enable
the miller part may look strange but this is correct cause this is the other site using our connection. so this can't be touched.
regards,
nicky
