Bookmark
Subscribe
1944
Port forwarding - Cisco 881-k9 v01
Mvuvi
I'm completely new to Cisco products, and would like to configure port forwarding in order to access my office server from my home laptop. My Cisco router is 881-k9 v01, and I've gone through a couple of commands but it's all very confusing.
All I've managed to do is connect through console using PuTTY. I'd appreciate the help.
6 Replies 6
here is a basic sample configuration:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 4.2.2.2
ip cef
username admin privilege 15 secret 5 $1$P4qP$h1hBpRrCmd2ZfOk/g9/yX0
archive
log config
hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN
ip address dhcp
duplex auto
speed auto
interface Vlan1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
password console
logging synchronous
login
no modem enable
line aux 0
password backdoor
login
line vty 0 4
password telnet
login
scheduler max-task-time 5000
end
Thanks Georg
Hello
You need to elaborate a little bit more -
First of all where does this Cisco router reside (office or home)
If at home then Is public web access already available to your office web server or does this need setting up also
If the router is at the office and you need to implement web access then does the router sit behind any firewall
Kind Regards
Paul
Hey Paul,
The router resides at the office and doesn't sit behind a firewall
Hello
@Mvuvi wrote:
Hey Paul,
thanks for the clarification-So apart from NAT running in this router does it have any software security feature enabled such as zone based fireall(ZB FW) or context based access control (cbac)
can you post the configuration of the router if applicable and leave out any public addressing or passwords etc...
Kind Regards
Paul
version 15.4
hostname Meridian_Anniversary
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp excluded-address xxx.xxx.x.x xxx.xxx.x.x
ip dhcp excluded-address xxx.xxx.x.xxx
ip dhcp pool ANNIVERSARRY
network xxx.xxx.x.x xxx.xxx.xxx.x
default-router xxx.xxx.x.x
dns-server xxx.xxx.xxx.xx x.x.x.x xx.xxx.xx.xx
ip name-server xx.xxx.xx.xx
ip name-server x.x.x.x
ip cef
no ipv6 cef
license udi pid C881-K9 sn FCZ1825C106
username soc password 7 xxxxxxxxxxxx
username admin password 0 xxxxxxxxx
username meridian password 7 xxxxxxxxxxxxxxxxxxxxxx
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key Meridian!2013 address xxx.xxx.xxx.xx
crypto ipsec transform-set HQ-LAVINGTON esp-3des esp-md5-hmac
mode transport
crypto ipsec profile protect-gre
set security-association lifetime seconds 86400
set transform-set HQ-LAVINGTON
interface Tunnel10
description TUNNEL-LAVINGTON-TOWN
ip address xxx.xx.xx.x xxx.xxx.xxx.xxx
tunnel source xx.xx.xxx.xxx
tunnel destination xxx.xxx.xxx.xx
tunnel protection ipsec profile protect-gre
no ip address
no ip address
no ip address
no ip address
description JTL INTERNET
no ip address
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
description LAN
ip address xxx.xxx.x.x xxx.xxx.xxx.x
ip nat inside
interface Dialer1
description JTL_WAN
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname Meridian
ppp chap password 7 xxxxxxxxxxxxxxxxxx
ppp pap sent-username Meridian password 7 xxxxxxxxxxxxxxxxx
no ip http server
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source static tcp xxx.xxx.x.xxx xxxx xx.xx.xxx.xxx xxxx extendable ip nat inside source static tcp xxx.xxx.x.xxx xxxx xx.xx.xxx.xxx xxxx extendable ip route 0.0.0.0 0.0.0.0 Dialer1 name JTL-Internet
ip route xxx.xxx.x.xxx xxx.xxx.xxx.x xxx.xxx.x.xxx name route_to_Lavington
access-list 102 permit ip xxx.xxx.x.x x.x.x.xxx any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
