Port forwarding confusion?
j_friedrich
Hi guys,
     Maybe someone can shed some insight on this....
ip nat inside source static tcp 192.168.167.5 10001 interface GigabitEthernet0/1 10001
This works, but, not what I want as it's sending this port to ONE ip.  It shows up in the 'show ip nat trans' command.
I have configured this instead to forward this port to one ip and possibly more in the future...
ip nat pool PORTFWD2 192.168.167.5 192.168.167.5 netmask 255.255.255.252 type rotary
ip nat inside destination list 103 pool PORTFWD2
access-list 103 permit tcp any host 192.168.167.5 eq 10000
Sooooooo, nothing is showing up in the 'matches' for this acl.  Also, nothing is going thru for forwarding.
Ideas?
Thanks for eveyone's time!
Jason
j_friedrich
Example should be:
access-list 103 permit tcp any host 192.168.167.5 eq 10001
Thanks.
