How to automatically shutdown PoE ports on 2960 switch during night
ramcm.rr
I would like to save power by scheduling the PoE switch ports on my switches to shutdown every night and turn on at a specified time during day. Does anyone know how to do it?
Ram
chris.macleod
Have a look at the feature "energywise"  Should be supported on your switch - might need to upgrade the IOS.
Sample from my config (3560)
Global
energywise domain xxx secret 0 xxx
energywise management 43440
Interface
energywise level 0 recurrence importance 90 at 00 22 * * 1-6
energywise level 10 recurrence importance 90 at 00 07 * * 1-6
I turned my POE power off on a per interface basis at 10pm then back on again at 7am.
thanks
Chris
6 Replies 6
chris.macleod
Global
Interface
thanks
Chris
Fantastic! Thanks Chris and Amit
Nice one Chris.  Been trying to get my EnergyWise in my lab working.
Do you have any configuration examples regarding EnergyWise time-range?
By the way ... EnergyWise commands between 12.2(58)SE1 and 15.0 are very "different".  The documentations have not yet been updated/upgraded.
Amit Singh
Very good post by Chris that's what you exactly need at minimum. If you want to manage that using a software and also looking for reporting, usage and regulate that via a Tool, you have 2 options :
1. Veridiam Orchestrator
2. Joulex Enteprise energy manager.
HTH,
-amit singh
What a woderful EnergyWise commands!!
Thanks all of you.
Leo Laohoo
Anyone planning to use EnergyWise can also use time-based ACL.
Here's my scenario:
Power ON
1.  Monday, Tuesday, Thursday and Friday:  8am to 5pm;
2.  Wednesday:  8am to 1030pm;
Power OFF:
1.  Monday, Tuesday, Thursday and Friday:  5pm to 8am the next day
2.  Wednesday:   1030pm to 8am the next day
3.  All Weekend
So here's my config:
!  Global
energywise domain security shared-secret
energywise importance 60
!  Interface
interface GigabitEthernet0/1
energywise level 10 recurrence importance 70 time-range ON
energywise level  0 recurrence importance 70 time-range OFF
!  Time Range
time-range _ON
absolute start 00:00 01 December 2012
periodic mon tues thurs friday 8:00 to 17:0
periodic wed 8:0 to 22:30
time-range OFF
periodic Monday Tuesday Thursday Friday 17:0 to 23:59
periodic Wednesday 22:30 to 23:59
periodic weekday 0:0 to 8:0
NOTE:
1.  There's a config I've seen (which I've lost) where you don't need the "OFF" time range.  Basically, EnergyWise is smart enough to say, "If the time now is within the time range, I'll use the ON.  However, if the time range is not the time now then I will TURN OFF the power to the port".
So far, I couldn't do this without the OFF statement.
2.  In the above example config, it takes the switch port 16 seconds to initiate the power OFF sequence.
3.  In the above example config, it takes the switch port  29 seconds to initiate the power ON sequence.
