Port forwarding in cisco router
krishan.saran
I am trying to run some NAT COMMANDS IN MY ROUTER BUT I DONT KNOW IF THERE IS ANY FORT RANGE COMMAND IN CISCO 800 SERIES ROUTERS,
I NEED TO FORWARD THE 16000 TO 32000 ON ONE PRIVATE IP
ANY BODY CAN PLS HELP ME
Jennifer Halim
Assuming that you are trying to NAT the RTP stream, here is configuration guide for your reference:
http://www.cisco.com/en/US/partner/docs/ios/ipaddr/configuration/guide/iad_pat_pt_rng.html
Hope that helps.
Jennifer Halim
Hope that helps.
Hope that helps.
Jennifer,
please check the URLs you post. Customers cannot access the ones that contains /partner/
