Port forwarding & nat
boonwah.yeo
Hello guys, need some help, i am very green in Networking.
Please help me in this commands.
Currently we have 2 office, in India n Singapore, without any wan connection between this 2 office. This India office has installed some wireles cam (192.168.1.15), I want to monitor this wireless cam in Singapore office, and also at the same time open up 18 ports (9101 - 9119) for the 18 cams, (192.168.1.15:9101 - 9119).
from my understanding, i believe i will need to get 1 WAN IP address to translate to their 192.168.1.15:9101 - 9119? So that from Singapore office, I can access to their cam through the India WAN ip?
Please advice the command.
Below is the config
boot-start-marker
boot-end-marker
enable secret 4 06YFDUHH61wAE/kLkDq9BGho1QM5EnRtoyr8cHAUg.2
aaa new-model
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.161 192.168.1.172
ip dhcp pool LAN
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.254
 dns-server 212.76.85.145 213.236.32.2
 lease 0 2
ip name-server 212.76.85.145
ip name-server 213.236.32.2
license udi pid CISCO1941/K9 sn FCZ162091HZ
username wael secret 4 n0V/y9uy56hzE90yiFc4hFTclRUtqGgKuR3D.Rw5PME
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Connected To POE - WAN
 ip address 172.21.5.90 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN
 ip address 192.168.1.254 255.255.255.0 secondary
 ip address 213.236.56.233 255.255.255.248
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 172.21.5.89
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 transport input all
scheduler allocate 20000 1000
end
Please advise the command to do this.
Best Regards
15 Replies 15
Emmanuel Valdez
Level 3
Level 3
Hi Yeo,
If you don´t want to use RDP you have to access camera by camera via NAT translation so you could have an access list that point to each ip address of the camera and its port, in this case you are nating the pc/server and not the cameras.
The most simple case it to NAT the server and display the cameras screen through the administration interface on the server, the RDP is only one example, there are more application to access a server like VNC, if your boss don´t want to use them because is very insecure you can change the default port of the application.
Regards.
