Port Forwarding not working
Mike Bolgar
I'm having a problem with port forwarding on my 1941W router.
I would like to forward ports 8001 and 2001 TCP from Internet to a local host on the internal network.
I am able to connect to the local host from the internal network, but it does not work from the Internet.
Here is my config:
version 15.0
hostname Router1
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
clock timezone EASTERN -4
clock summer-time PCTime date Apr 6 2003 3:00 Oct 26 2003 3:00
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 10.20.7.0 10.20.7.49
ip dhcp excluded-address 10.20.7.250 10.20.7.255
ip dhcp pool ccp-pool1
   import all
   network 10.20.6.0 255.255.254.0
   default-router 10.20.7.1
ip domain name xxxxxx.com
license udi pid CISCO1941W-A/K9 sn FGL153026TT
hw-module ism 0
username xxxxxx privilege 15 password 0 xxxxxx
no ip ftp passive
policy-map sdm-qos-test-123
class class-default
bridge irb
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport trunk native vlan 2
switchport mode trunk
interface GigabitEthernet0/0
description LAN interface$ES_LAN$
no ip address
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
bridge-group 2
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered BVI2
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description WAN interface
ip address dhcp client-id GigabitEthernet0/1
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
ip nat inside
interface Vlan2
no ip address
bridge-group 2
interface BVI2
ip address 10.20.7.1 255.255.254.0
ip nat inside
no ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.20.7.21 8001 interface GigabitEthernet0/1 8001
ip nat inside source static tcp 10.20.7.21 2001 interface GigabitEthernet0/1 2001
ip nat inside source static tcp 10.20.7.22 8002 interface GigabitEthernet0/1 8002
ip nat inside source static tcp 10.20.7.22 2002 interface GigabitEthernet0/1 2002
ip nat inside source static tcp 10.20.7.23 8003 interface GigabitEthernet0/1 8003
ip nat inside source static tcp 10.20.7.23 2003 interface GigabitEthernet0/1 2003
ip nat inside source static tcp 10.20.7.24 8004 interface GigabitEthernet0/1 8004
ip nat inside source static tcp 10.20.7.24 2004 interface GigabitEthernet0/1 2004
ip nat inside source static tcp 10.20.7.25 8005 interface GigabitEthernet0/1 8005
ip nat inside source static tcp 10.20.7.25 2005 interface GigabitEthernet0/1 2005
ip nat inside source static tcp 10.20.7.26 8006 interface GigabitEthernet0/1 8006
ip nat inside source static tcp 10.20.7.26 2006 interface GigabitEthernet0/1 2006
ip nat inside source static tcp 10.20.7.27 8007 interface GigabitEthernet0/1 8007
ip nat inside source static tcp 10.20.7.27 2007 interface GigabitEthernet0/1 2007
ip route 0.0.0.0 0.0.0.0 dhcp
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 dhcp
access-list 1 permit 10.20.7.0 0.0.0.255
access-list 1 permit 10.20.6.0 0.0.0.255
control-plane
bridge 2 protocol ieee
bridge 2 route ip
alias exec s sh ip int br
line con 0
exec-timeout 0 0
line aux 0
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp master
ntp update-calendar
end
Peter Paluch
Hello Mike,
A couple of questions and hints:
  • The ip nat inside command present on your Gi0/0 and Vlan1 interfaces is useless, as these interfaces are currently not configured for IP operation. I suggest removing this command from both interfaces.
  • The Wlan-Gigabit0/0 interface is configured as a trunk with VLAN 2 being the native. Are you using multiple SSIDs mapped to different VLANs? Also, does the native VLAN match the configuration of the embedded access point?
  • Your basic NAT configuration appears to be correct. Can you perhaps post the output of the show ip nat translation command?
  • Have you ensured with your ISP that the direct access to the ports 8001-8007 and 2001-2007 is allowed by his own settings? Is it perhaps possible that the ISP filters incoming connections to these ports?
Best regards,
Peter
