Port Forwarding to IP Address 192.168.11.61 (Urgent Req)
dc-csa-blr
Dear Experts,
Please guide me following ports i need to Forwarding to IP Address 192.168.11.61
The port details are as follows:
(1) TCP Port 22 (SSH)
(2) UDP Port 500 (ISAKMP)
(3) UDP Port 4500 (ISAKMP/NAT-Traversal)
(4) IP50 (AH)
(5) IP51 (ESP)
What is the command should i give and how can i apply in my router as per my above mention required ??
Thanks in Adv,
2 Accepted Solutions
cadet alain
which model of router? if it is an enterprise model and your outside interface is x.x.x.x then you could do something like this:
access-list 199 permit tcp  host 192.168.11.61 eq 22 any
access-list 199 permit udp host 192.168.11.61 eq 500 any
access-list 199 permit udp  host 192.168.11.61 eq 4500 any
access-list 199 permit esp host 192.168.11.61  any
access-list 199 permit ah host 192.168.11.61  any
route-map MY_SERVICES
match ip address 199
ip nat inside source static 192.168.11.61 x.x.x.x route-map MY_SERVICES
on inside interface: ip nat inside
on outside interface: ip nat outside
Regards.
Alain
your outside public address.
Regards.
Alain
5 Replies 5
cadet alain
Regards.
Alain
Dear Alain,
Thanks so much some confusion pl clear me.
ip nat inside source static 192.168.11.61 x.x.x.x route-map MY_SERVICES ( here x.x.x.x means ??)
Thanks once again!!!
Regards.
Alain
Dear alain,
Thanks a lot i will try to config and then let you.
Have Cheers!!!
fb_webuser
Level 6
Level 6
the command you will use is : ip nat inside source static tcp 192.168.11.61 22 1.1.1.1 22 1.1.1.1 22 extendable. thats an example of the configuration. you can neither use the interface associate with the public IP address listed in this command as 1.1.1.1 (as an example) or use the interface instead of the ip address. regards
Posted by WebUser Julio C. Padilla
