routing between two VPNs on same interface
MikeCaditz
I have both a Easy VPN server and a site-to-site VPN on the same outside interface of a 2911 router.
Currently, a Easy VPN client has no route int the router then out the site-to-site VPN to the remote site.
How can I create this route?
Building configuration...
Current configuration : 18830 bytes
! Last configuration change at 19:01:55 PCTime Tue Nov 29 2011 by admin
! NVRAM config last updated at 19:02:42 PCTime Tue Nov 29 2011 by admin
version 15.1
hostname SFGallery
boot-start-marker
boot-end-marker
no logging buffered
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login ciscocp_vpn_xauth_ml_2 local
aaa authentication login ciscocp_vpn_xauth_ml_3 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_2 local
aaa session-id common
clock timezone PCTime -7 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ipv6 cef
ip source-route
ip cef
ip domain name gpgallery.com
ip name-server 10.10.10.10
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 10.10.10.80
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki trustpoint SFGallery_Certificate
enrollment selfsigned
serial-number none
ip-address none
rsakeypair SFGallery_Certificate_RSAKey 512
crypto pki certificate chain test_trustpoint_config_created_for_sdm
crypto pki certificate chain SFGallery_Certificate
certificate self-signed 01
  xxxx
            quit
license udi pid CISCO2911/K9 sn xxxxxx
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package datak9
object-group network Corp
172.16.4.0 255.255.252.0
10.10.10.128 255.255.255.224
object-group network SFGallery
172.16.0.0 255.255.252.0
10.10.10.0 255.255.255.128
object-group network NY
10.10.10.160 255.255.255.224
object-group network GPAll
group-object SFGallery
group-object NY
group-object Corp
username xxx privilege 15 secret 5 xxxx
username  xxx privilege 15 secret 5 $xxx
username xxxx privilege 15 secret 5 $xxxxx
redundancy
no ip ftp passive
ip ssh version 1
class-map type inspect match-all CCP_SSLVPN
match access-group name CCP_IP
policy-map type inspect ccp-sslvpn-pol
class type inspect CCP_SSLVPN
  pass
zone security sslvpn-zone
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxx address 209.101.19.226
crypto isakmp client configuration group SFGallery
key xxxxxx
dns 10.10.10.10 10.10.10.80
wins 10.10.10.10 10.10.10.80
domain gpgallery.com
pool SDM_POOL_1
acl 111
save-password
split-dns gpgallery.com
max-users 25
max-logins 2
netmask 255.255.252.0
banner ^CWelcome to GP Gallery . . . ^C
crypto isakmp profile ciscocp-ike-profile-1
   match identity group SFGallery
   client authentication list ciscocp_vpn_xauth_ml_3
   isakmp authorization list ciscocp_vpn_group_ml_2
   client configuration address respond
   virtual-template 3
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA3 esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 43200
set transform-set ESP-3DES-SHA3
set isakmp-profile ciscocp-ike-profile-1
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to209.101.19.226
set peer 209.101.19.226
set transform-set ESP-3DES-SHA1
match address 107
interface Loopback1
ip address 192.168.5.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description T1 Cybermesa$ETH-WAN$
ip address 65.19.62.60 255.255.255.240
ip access-group 105 in
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LANOverloadNet$ETH-WAN$
ip address 172.16.0.1 255.255.252.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
description LAN$ETH-LAN$
ip address 10.10.10.2 255.255.255.128
ip access-group 100 in
ip nat inside
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered Loopback1
interface Virtual-Template2
zone-member security sslvpn-zone
interface Virtual-Template3 type tunnel
ip unnumbered GigabitEthernet0/0
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
ip local pool SDM_POOL_1 172.16.3.200 172.16.3.254
ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 10
sort-by bytes
cache-timeout 60000
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip nat inside source route-map SDM_RMAP_4 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 65.19.62.49 permanent
ip route 10.10.10.0 255.255.255.128 GigabitEthernet0/2 permanent
ip route 10.10.10.128 255.255.255.224 10.10.10.126 permanent
ip route 172.16.4.0 255.255.252.0 10.10.10.126 permanent
ip access-list extended CCP_IP
remark CCP_ACL Category=128
permit ip any any
no logging trap
logging 10.10.10.107
access-list 1 permit 192.168.1.2
access-list 1 remark CCP_ACL Category=1
access-list 1 permit 72.216.51.56 0.0.0.7
access-list 1 permit 172.16.0.0 0.0.3.255
access-list 1 permit 172.16.4.0 0.0.3.255
access-list 1 permit 10.10.10.128 0.0.0.31
access-list 1 remark Auto generated by SDM Management Access feature
access-list 1 permit 65.19.62.48 0.0.0.15
access-list 1 permit 10.10.10.0 0.0.0.127
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark CCP_ACL Category=1
access-list 100 permit ip any host 10.10.10.2
access-list 100 permit tcp object-group GPAll host 10.10.10.2 eq telnet
access-list 100 permit tcp 172.16.4.0 0.0.3.255 host 10.10.10.2 eq telnet
access-list 100 permit tcp 10.10.10.128 0.0.0.31 host 10.10.10.2 eq telnet
access-list 100 permit tcp 10.10.10.0 0.0.0.127 host 10.10.10.2 eq telnet
access-list 100 permit tcp object-group GPAll host 10.10.10.2 eq 22
access-list 100 permit tcp 172.16.4.0 0.0.3.255 host 10.10.10.2 eq 22
access-list 100 permit tcp 10.10.10.128 0.0.0.31 host 10.10.10.2 eq 22
access-list 100 permit tcp 10.10.10.0 0.0.0.127 host 10.10.10.2 eq 22
access-list 100 permit tcp object-group GPAll host 10.10.10.2 eq www
access-list 100 permit tcp 172.16.4.0 0.0.3.255 host 10.10.10.2 eq www
access-list 100 permit tcp 10.10.10.128 0.0.0.31 host 10.10.10.2 eq www
access-list 100 permit tcp 10.10.10.0 0.0.0.127 host 10.10.10.2 eq www
access-list 100 permit tcp object-group GPAll host 10.10.10.2 eq 443
access-list 100 permit tcp 172.16.4.0 0.0.3.255 host 10.10.10.2 eq 443
access-list 100 permit tcp 10.10.10.128 0.0.0.31 host 10.10.10.2 eq 443
access-list 100 permit tcp 10.10.10.0 0.0.0.127 host 10.10.10.2 eq 443
access-list 100 permit tcp object-group GPAll host 10.10.10.2 eq cmd
access-list 100 permit tcp 172.16.4.0 0.0.3.255 host 10.10.10.2 eq cmd
access-list 100 permit tcp 10.10.10.128 0.0.0.31 host 10.10.10.2 eq cmd
access-list 100 permit tcp 10.10.10.0 0.0.0.127 host 10.10.10.2 eq cmd
access-list 100 deny   tcp any host 10.10.10.2 eq telnet
access-list 100 deny   tcp any host 10.10.10.2 eq 22
access-list 100 deny   tcp any host 10.10.10.2 eq www
access-list 100 deny   tcp any host 10.10.10.2 eq 443
access-list 100 deny   tcp any host 10.10.10.2 eq cmd
access-list 100 deny   udp any host 10.10.10.2 eq snmp
access-list 100 permit udp any eq domain host 10.10.10.2
access-list 100 permit udp host 10.10.10.80 eq domain any
access-list 100 permit udp host 10.10.10.10 eq domain any
access-list 100 permit ip any any
access-list 101 remark Auto generated by SDM Management Access feature
access-list 101 remark CCP_ACL Category=1
access-list 101 permit ip 72.216.51.56 0.0.0.7 any
access-list 101 permit ip 172.16.0.0 0.0.3.255 any
access-list 101 permit ip 172.16.4.0 0.0.3.255 any
access-list 101 permit ip 10.10.10.128 0.0.0.31 any
access-list 101 permit ip 65.19.62.48 0.0.0.15 any
access-list 101 permit ip host 192.168.1.2 any
access-list 101 permit ip 10.10.10.0 0.0.0.127 any
access-list 102 remark Auto generated by SDM Management Access feature
access-list 102 remark CCP_ACL Category=1
access-list 102 permit ip 72.216.51.56 0.0.0.7 any
access-list 102 permit ip 172.16.0.0 0.0.3.255 any
access-list 102 permit ip 172.16.4.0 0.0.3.255 any
access-list 102 permit ip 10.10.10.128 0.0.0.31 any
access-list 102 permit ip 65.19.62.48 0.0.0.15 any
access-list 102 permit ip host 192.168.1.2 any
access-list 102 permit ip 10.10.10.0 0.0.0.127 any
access-list 103 remark Auto generated by SDM Management Access feature
access-list 103 remark CCP_ACL Category=1
access-list 103 permit tcp host 192.168.1.2 host 172.16.0.1 eq telnet
access-list 103 permit tcp host 192.168.1.2 host 172.16.0.1 eq 22
access-list 103 permit tcp host 192.168.1.2 host 172.16.0.1 eq www
access-list 103 permit tcp host 192.168.1.2 host 172.16.0.1 eq 443
access-list 103 permit tcp host 192.168.1.2 host 172.16.0.1 eq cmd
access-list 103 deny   tcp any host 172.16.0.1 eq telnet
access-list 103 deny   tcp any host 172.16.0.1 eq 22
access-list 103 deny   tcp any host 172.16.0.1 eq www
access-list 103 deny   tcp any host 172.16.0.1 eq 443
access-list 103 deny   tcp any host 172.16.0.1 eq cmd
access-list 103 deny   udp any host 172.16.0.1 eq snmp
access-list 103 permit ip any any
access-list 104 remark CCP_ACL Category=4
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.10.10.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 104 permit ip 10.10.10.0 0.0.0.255 10.10.10.160 0.0.0.31
access-list 105 remark Auto generated by SDM Management Access feature
access-list 105 remark CCP_ACL Category=1
access-list 105 permit tcp 72.216.51.56 0.0.0.7 host 65.19.62.60 eq telnet
access-list 105 permit tcp 172.16.0.0 0.0.3.255 host 65.19.62.60 eq telnet
access-list 105 permit tcp 65.19.62.48 0.0.0.15 host 65.19.62.60 eq telnet
access-list 105 permit tcp 72.216.51.56 0.0.0.7 host 65.19.62.60 eq 22
access-list 105 permit tcp 172.16.0.0 0.0.3.255 host 65.19.62.60 eq 22
access-list 105 permit tcp 65.19.62.48 0.0.0.15 host 65.19.62.60 eq 22
access-list 105 permit tcp 72.216.51.56 0.0.0.7 host 65.19.62.60 eq www
access-list 105 permit tcp 172.16.0.0 0.0.3.255 host 65.19.62.60 eq www
access-list 105 permit tcp 65.19.62.48 0.0.0.15 host 65.19.62.60 eq www
access-list 105 permit tcp 72.216.51.56 0.0.0.7 host 65.19.62.60 eq 443
access-list 105 permit tcp 172.16.0.0 0.0.3.255 host 65.19.62.60 eq 443
access-list 105 permit tcp 65.19.62.48 0.0.0.15 host 65.19.62.60 eq 443
access-list 105 permit tcp 72.216.51.56 0.0.0.7 host 65.19.62.60 eq cmd
access-list 105 permit tcp 172.16.0.0 0.0.3.255 host 65.19.62.60 eq cmd
access-list 105 permit tcp 65.19.62.48 0.0.0.15 host 65.19.62.60 eq cmd
access-list 105 deny   tcp any host 65.19.62.60 eq telnet
access-list 105 deny   tcp any host 65.19.62.60 eq 22
access-list 105 deny   tcp any host 65.19.62.60 eq www
access-list 105 deny   tcp any host 65.19.62.60 eq 443
access-list 105 deny   tcp any host 65.19.62.60 eq cmd
access-list 105 deny   udp any host 65.19.62.60 eq snmp
access-list 105 permit tcp any host 65.19.62.61 eq 443
access-list 105 permit ip 10.10.10.160 0.0.0.31 10.10.10.0 0.0.0.127
access-list 105 remark IPSec Rule
access-list 105 permit ip 10.10.10.160 0.0.0.31 10.10.10.0 0.0.0.255
access-list 105 permit udp any eq domain host 65.19.62.60
access-list 105 permit ahp host 209.101.19.226 host 65.19.62.60
access-list 105 permit esp host 209.101.19.226 host 65.19.62.60
access-list 105 permit udp host 209.101.19.226 host 65.19.62.60 eq isakmp
access-list 105 permit udp host 209.101.19.226 host 65.19.62.60 eq non500-isakmp
access-list 105 permit ip 10.10.10.0 0.0.0.127 10.10.10.0 0.0.0.127
access-list 105 permit ip any any
access-list 106 remark CCP_ACL Category=2
access-list 106 remark IPSec Rule
access-list 106 deny   ip 10.10.10.0 0.0.0.255 10.10.10.160 0.0.0.31
access-list 106 deny   ip 10.10.10.0 0.0.0.127 10.10.10.160 0.0.0.31
access-list 106 deny   ip 10.10.10.0 0.0.0.127 10.10.10.0 0.0.0.127
access-list 106 permit ip 10.10.10.0 0.0.0.255 any
access-list 107 remark CCP_ACL Category=4
access-list 107 remark IPSec Rule
access-list 107 permit ip 10.10.10.0 0.0.0.255 10.10.10.160 0.0.0.31
access-list 108 remark CCP_ACL Category=2
access-list 108 remark IPSec Rule
access-list 108 deny   ip 10.10.10.0 0.0.0.255 10.10.10.160 0.0.0.31
access-list 108 permit ip 70.56.215.0 0.0.0.255 any
access-list 109 remark CCP_ACL Category=2
access-list 109 remark IPSec Rule
access-list 109 deny   ip 10.10.10.0 0.0.0.255 10.10.10.160 0.0.0.31
access-list 109 permit ip 172.16.0.0 0.0.255.255 any
access-list 111 remark CCP_ACL Category=4
access-list 111 permit ip 10.10.10.0 0.0.0.127 any
access-list 111 permit ip 10.10.10.128 0.0.0.31 any
access-list 111 permit ip 172.16.0.0 0.0.3.255 any
access-list 111 permit ip 172.16.4.0 0.0.3.255 any
access-list 111 permit ip 10.10.10.160 0.0.0.31 any
route-map SDM_RMAP_4 permit 1
match ip address 109
route-map SDM_RMAP_1 permit 1
match ip address 106
route-map SDM_RMAP_2 permit 1
match ip address 108
snmp-server community public RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps transceiver all
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps license
snmp-server enable traps envmon
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps flash insertion removal
snmp-server enable traps c3g
snmp-server enable traps ds3
snmp-server enable traps adslline
snmp-server enable traps vdsl2line
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps energywise
snmp-server enable traps vstack
snmp-server enable traps mac-notification
snmp-server enable traps bgp
snmp-server enable traps isis
snmp-server enable traps rf
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps memory bufferpeak
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps resource-policy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps nhrp nhs
snmp-server enable traps nhrp nhc
snmp-server enable traps nhrp nhp
snmp-server enable traps nhrp quota-exceeded
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps l2tun pseudowire status
snmp-server enable traps vtp
snmp-server enable traps ipsla
snmp-server enable traps bfd
snmp-server enable traps firewall serverstatus
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server host 10.10.10.107 public
control-plane
banner login ^CCWelcome to Santa Fe Gallery Cisco 2911 router 10.10.10.1.^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 102 in
transport input telnet
line vty 5 15
access-class 101 in
scheduler allocate 20000 1000
end
Sam Smiley
Level 3
Level 3
Hi Michael,
The answer is in the crypto map configuration...
match address 107
reverse-route
This will allow your remote clients to access either site.
Cheers,
Sam
