Port Forwarding Using a QNAP as an L2TP server
rjratliff
Hello all,
I am stuck.  I have connected a QNAP TS-451+ NAS behind my router.  I am trying to use it as my VPN, but when I set up port forwarding on the router I am not having any luck.  It appears that I am forgetting something.
I have tried ip nat inside source static udp 192.168.xxx.xxx 500 interface Fa0/0 500 for all three ports (500/1701/4500) needed for L2TP, but I cannot seem to connect.
Any advice would be appreciated.
13 Replies 13
I assume the 192.168.xxx.xxx address is the fixed LAN IP address of the NAS ? As described in point 4 of the attached guide ?
https://www.qnap.com/en/tutorial/con_show.php?op=showone&cid=3
That is correct
try to add the 'extendable' keyword to your static NAT entries, e.g.:
ip nat inside source static udp 192.168.xxx.xxx 500 interface Fa0/0 500 extendable
The router would not accept the extendable command.
try and use the actual IP address of the Fa0/0 in your NAT statement.
ip nat inside source static udp 192.168.xxx.xxx. 500 xxx.xxx.xxx.xxx 500
I have a DHCP internet connection.  Are you saying assign the second group the routers ip, or the ip assigned from the isp?
Francesco Molino
I assume you've followed all QNAP steps for allowing VPN.
Do you have some logs on QNAP? Does the traffic arrives to the QNAP or not?
Have you checked the NAT on the router and did you do a debug ip packet to validate that traffic is routed to your QNAP device?
Is there any acl on the router? And what about the embedded firewall on your QNAP, did you opened all L2TP ports?
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
I have followed all QNAP instructions and enabled everything.  The logs on the QNAP list nothing.
To be honest, I am not familiar with how to debug with ip packet.
All ports should be opened.  I am listing my current config below.
Thanks!
Using 1604 out of 245752 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$qYXt$LQzyFm1E0Rli6M2bFBsS91
enable password XXXXXXXXXX
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.234
ip dhcp pool HOME_CLIENTS
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
voice-card 0
 no dspfarm
archive
 log config
  hidekeys
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
speed auto
interface GigabitEthernet0/1
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source static udp 192.168.1.5 500 interface GigabitEthernet0/0 500
ip nat inside source static udp 192.168.1.5 1701 interface GigabitEthernet0/0 1701
ip nat inside source static udp 192.168.1.5 4500 interface GigabitEthernet0/0 4500
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
 password XXXXXXXXXXX
 login
scheduler allocate 20000 1000
end
Ok thanks.
Can you paste the output of show ip nat transl ?
Francesco
Pro Inside global      Inside local       Outside local      Outside global
udp 76.xxx.xx.xx:500   192.168.1.5:500    ---                ---
udp 76.xxx.xx.xx:1701  192.168.1.5:1701   ---                ---
udp 76.xxx.xx.xx:4500  192.168.1.5:4500   ---                ---
We will do a global acl (IP mot just UDP) to see what traffic is going through that server.
access-list 100 permit ip any host 192.168.1.5
debug ip packet 100 detail
Then, try to connect and copy/paste to this forum the output you had. Please put it into a text file.
Francesco
Here we go
On your log file, there is a chat you had :-)
Seriously, did you tried to connect in L2TP? I see traffic forwarded to your NAS-Server.
Can you do the same test but add the statement below in your acl, to verify if it replies back:
access-list 100 permit ip host 192.168.1.5 any
I'm not very familiar with QNAP (I mostly use Synology) but could you check if you can enable some detailed logs ?
Does the firewall is enabled on QNAP?
Francesco
