5506 ASA with EIGRP Routing
Joshuabowers
I think I noticed a limitation of the asa 5506 and just want to make sure that I'm correct.
When I run EIGRP Routing on the asa I noticed that the ASA doesn't have equal cost load balancing.
I tried to up the max path and variance but the commands don't seem to exist. Is this correct?
Deepak Kumar
ASA is not a routing device, this is a security device. All dynamic routing protocols are a bit limited on the ASA but if you understand and work within those limitations it can be useful.
More information about EIGRP on ASA
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar
Deepak Kumar,
