Port licensing ASR 1001/2-HX License
denz_cruel
We are planning to purchase ASR 1001-HX Router because of the 10 GE ports. We were quoted for four FLSA1-HX-2X10GE and we only need four 10 GE ports. What I understand on the link below is that ASR by default, the first 4 ports on bay 0 and bay 1 can be enable without a license.
Do we really need to purchase FLSA1-HX-2X10GE even though we just need four 10GE ports?
License https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001HX_1002HX/b_ASR1001HX-1002HX_HIG/b_ASR1001HX-1002HX_HIG_chapter_0110.html
https://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/datasheet-c78-731632.html
greensubmarine
ASR1001-HX has 8 GigaPorts and 8 10G SFP+ Ports in total .
4 GigaPorts and 4 10G SFP+ Ports can be used without licenses.
Other ports are noted with configurable , which needs licenses to be activated .
When you use CCW to configure ASR1001-HX , you may find there can only be configured with 2 licenses of 2-GigaPort and 2 licenses of 2-10G Port (total 4 licenses).
Thanks for valuable information.
What about the additional slot cards? For example EPA-18x1GE.
Does this require also the port license or are these ports free to use? Otherwise I would need that 2 port license 9 times, right?
