Port Speed VS Throughput
layne.peterson1
I have a question about the limitation the speed of a port will actually put on real world throughput. I have a client that has a 150 meg pipe from their provider, and they want a firewall that will give them the full throughput without having a bottleneck. I was looking at an ASA 5510, but it only has Fast Ethernet ports. In theory they shouldn't be able to get over 100 Megs since there aren't any Gig ports right, and the port that connects to the ISP would be the bottleneck.
I understand they could have higher throughput locally since there are multiple ports, and combined they would add up to more than the 100 Meg limit on a single interface, but accessing the internet they would be limited to 100 Megs max, which would be even less once services are enabled, correct?
Jon Marshall
Correct, the limiting factor would be the interface connecting to the ISP and that would be the bottleneck assuming of course you were generating more than 100Mbps of traffic.
Jon
