Hi,cisco.
I have a problem about ERASE flash contents.
I entered ROMmon mode.
But I didn't search anything else ; erase, delete commands...
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of motherboard cookie PROM in hex
dev list the device table
dir list files in file system
dis disassemble instruction stream
dnld serial download a program module
frame print out a selected stack frame
gioshow show the gio version
help monitor builtin command help
history monitor command history
iomemset set IO memory percent
meminfo main memory information
repeat repeat a monitor command
reset system reset
rommon-pref Select ROMMON
set display the monitor variables
showmon display currently selected ROM monitor
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
tftpdnld tftp image download
unalias unset an alias
unset unset a monitor variable
xmodem x/ymodem image download
I could see these commands.
As you see those, which command is that I find?
plz recommend one!
- See more at: https://supportforums.cisco.com/discussion/12511766/rommon-mode-how-erase-flash#sthash.KRHiOlS3.dpuf
Router? Switch? Model #?
Try
xmodem ?
-e = (Optional) Erases the first partition in Flash memory before starting the download. This option is only valid for the Cisco 1600 series.
-f = (Optional) Erases all Flash memory before starting the download. This option is only valid for the Cisco 1600 series routers.
What is the issue?
Not booting up due to no ios? corrupt ios? ??
I assuming you are trying to delete flash? If not, what are you trying to accomplish?
Hope this helps...
Ah..
I'm trying to delete IOS in Flash Memory.
Cisco router model is "CISCO 2811"
I bought it a week ago.
But IOS is not listed in. So, because I have a flash memory, I inserted it to the Router.
However, in this Flash Memory, 7000 series IOS was listed.. So there was no spare memory capacity.
So,
To delete 7000 series memory, I tried but there was no command I knew.
Because of its reason, I posted my question.
If you are able to boot the router, then you can delete the flash content from there easily.
Other thing is you should be getting delete option in the Rommon mode
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/rommon.html
Thank you for replying.
But, as I referred, NO delete command in the router. So I posted it here.
Hmmm...
what should I do to delete flash memory image in the ROMmon mode?;;
In the Rommon mode, isn't there any other command???
If your laptop doesn't have a supported port, You can get an usb external card reader that will connect to your laptop, insert flash into the card reader and delete it from your laptop.
Ah... I have no one..
hmm. the best method is only your opinion??
Posts in this discussion have been modified due to possible misconduct. Please refer to the CSC terms of use for more details. https://supportforums.cisco.com/document/29951/cisco-support-community-acceptable-use-agreement |
Then,,, should I delete this post?;;
Yes.
Posts in this discussion has been modified to comply to the CSC terms of use conditions, so you can keep the post here.
Will a message be sent to the person who's posting contained misconduct?
Thanks.
