Possible Asymmetric routing problem
BluePho982
Hello everybody. I have a Cisco 2801 with dual ADSL WAN.
I can reach only one of the two IP WAN at time: I can ping one but not the other: an so i can reach 192.168.1.101 only sometimes.
I think it's a asymmetric routing problem, right ? How can I solve it?
This is my config:
ip dhcp pool LAN_1
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 8.8.8.8
ip cef
no ip domain lookup
interface FastEthernet0/0
 description -> SWITCH
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface ATM0/1/0
 no ip address
 no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
 pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface ATM0/3/0
 no ip address
interface ATM0/3/0.1 point-to-point
 pvc 8/35
  dialer pool-member 2
interface Dialer0
 ip address x.x.x.x 255.255.255.252
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp authentication chap callin
 no cdp enable
interface Dialer1
 ip address y.y.y.y 255.255.255.252
 ip nat outside
 encapsulation ppp
 dialer pool 2
 no cdp enable
ip forward-protocol nd
ip http server
ip nat inside source static tcp 192.168.1.101 80 interface Dialer1 80
ip nat inside source route-map lan-wan-pri interface Dialer0 overload
ip nat inside source route-map lan-wan-sec interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 Dialer1
logging esm config
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
route-map lan-wan-sec permit 10
 match ip address 110
 match interface Dialer1
route-map lan-wan-pri permit 10
 match interface Dialer0
12 Replies 12
trfinkenstadt
When you say you can only reach 192.168.1.101 some of the time, you really mean you can only reach y.y.y.y:80 during that time?  It looks like you are doing a loadbalancing NAT outbound from your site.   You can solve this by doing a policy-based routing based on the source IP:Port coming in fast0/0 to force it out through dialer1:
Ip access-list extended PBR-WEB-ACL
 permit tcp host 192.168.1.101 eq 80 any
route-map PBR-WEB-RM permit 10
 match ip address PBR-WEB-ACL
 set ip next-hop y.y.y.Y
int fast0/0
 ip policy route-map PBR-WEB-ACL
HTH,
tim
Even if I get the following result, I cant' reach the 192.168.1.101...
for example:
Pro Inside global         Inside local          Outside local         Outside global
tcp y.y.y.y:80      192.168.1.101:80      79.25.112.38:56132    79.25.112.38:56132
tcp y.y.y.y:80      192.168.1.101:80      79.25.112.38:56133    79.25.112.38:56133
tcp y.y.y.y:80      192.168.1.101:80      79.25.112.38:56134    79.25.112.38:56134
tcp y.y.y.y:80      192.168.1.101:80      79.25.112.38:56135    79.25.112.38:56135
tcp y.y.y.y:80      192.168.1.101:80      79.25.112.38:56136    79.25.112.38:56136
tcp y.y.y.y:80      192.168.1.101:80      79.25.112.38:56137    79.25.112.38:56137
tcp y.y.y.y:80      192.168.1.101:80      151.19.34.161:56999   151.19.34.161:56999
tcp y.y.y.y:80      192.168.1.101:80      ---                   ---
Extended IP access list 110
Extended IP access list 112
    10 permit tcp host 192.168.1.101 eq www any (183 matches)
    20 permit udp host 192.168.1.101 range 0 65535 any (48 matches)
Those outputs show inbound connections but do not confirm two way traffic. You should go with a PBR setup like trfinkenstadt mentioned.
I tried a PBR config like this, but it doesn't work:
 ip nat inside
 ip policy route-map webcam-routing-patch
 duplex auto
 speed auto
ip http server
logging esm config
access-list 111 deny   ip host 192.168.1.101 any
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
access-list 112 permit tcp host 192.168.1.101 eq www any
access-list 112 permit udp host 192.168.1.101 range 0 65535 any
route-map webcam-routing-patch permit 10
 match ip address 112
 set ip next-hop y.y.y.y
 match ip address 111
When you add "next-hop y.y.y.y" are you putting the default gateway as y.y.y.y or the actual interface IP of Dialer1? The next hop IP should be the gateway IP that Dialer1 uses.
y.y.y.y is the public IP related to Dialer 1
Change that part of the route-map to the IP of the gateway that dialer1 uses then try it again. The public IP for dialer 1 isn't the next hop.
There are only 3 IP address configured in the router related one to LAN and two to WANs What do you mean about "the IP of the gateway that dialer1 "?
The situation is that:
95.x.x.x.x -> IP public of Dialer 0
79.y.y.y.y. -> IP public of Dialer 1
192.168.1.1 -> Ip of Fa0/0 (gateway of the LAN)
What Jason means is you can't set the next hop to the router's own IP, you set it to the IP of the next L3 device your router connects to on that interface.
If you don't know that then in your PBR configuration change -
"set ip next-hop y.y.y.y"
to
"set interface Dialer1"
Jon
the problem still remains. I've tried the following config too, but i can't reach the two public IP at the same time: i can ping the "95.x.x.x" or the "79.y.y.y."
alternately and randomly. So,
the same problem remains if I try to reach the 192.168.1.101 machine within the LAN: sometimes i can reach it, sometimes i can't.
boot-start-marker
boot system flash:c2801-entbase-mz.151-3.T.bin
boot-end-marker
logging buffered 4096 informational
logging monitor informational
no aaa new-model
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.100
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.1.101
ip dhcp pool LAN_1
dns-server 8.8.8.8
ip cef
no ip domain lookup
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
pvc 8/35
interface ATM0/3/0
no ip address
pvc 8/35
interface Dialer0
ip address 95.x.x.x 255.255.255.252
ip nat outside
encapsulation ppp
ip policy route-map avoid-asymm-95-IN-79-OUT
dialer pool 1
no cdp enable
interface Dialer1
ip address 79.y.y.y 255.255.255.252
ip nat outside
encapsulation ppp
ip policy route-map avoid-asymm-79-IN-95-OUT
dialer pool 2
no cdp enable
ip http server
logging esm config
access-list 113 permit tcp any host 79.y.y.y
access-list 113 permit icmp any host 79.y.y.y
access-list 114 permit tcp any host 95.x.x.x
access-list 114 permit icmp any host 95.x.x.x
route-map avoid-asymm-79-IN-95-OUT permit 10
match ip address 113
set tag 1
route-map avoid-asymm-79-IN-95-OUT permit 20
match tag 2
set interface dialer0
route-map avoid-asymm-95-IN-79-OUT permit 10
match ip address 114
set tag 2
route-map avoid-asymm-95-IN-79-OUT permit 20
match tag 1
set interface dialer1
end
If the only address that need special treatment is the .101 address then try this:
ip access-list standard NATLIST
 permit 192.168.1.0 0.0.0.255
ip nat inside source list NATLIST interface Dialer0 overload
ip nat inside source list NATLIST interface Dialer1 overload
ip access-list extended SERVER
route-map SERVER_PBR permit 10
match ip address SERVER
set interface dialer 1
ip policy SERVER_PBR
Go ahead and remove that load balacing policy stuff. Also make sure your cef loadsharing is default which should be based on destination address.
I've tried this config, but it doesnt' works: same problem: sometime i can reach the machine, sometime i can't
