possible to have multiple VRF but 1 physical link?
cisc0.ameer
Hello all
suppose in a question asked to configure PE - CE with eBGP for each(under) VRF
 in the PE because we configured VRF it is possible with 1 physical Link
but in other side on CE just we have normal Configuration of any Routing Protocol (in this case BGP)
in CE router is it possible we configured like this:
CE#router bgp 501
neighbor 1.2.3.4 remote-as 500
neighbor 1.2.5.5 remote-as 500
neighbor 1.2.6.6 remote-as 500
PE#router bgp 500
address-family ipv4 vrf A
neighbor 1.2.3.3 remote-as 501
neighbor 1.2.3.3 activate
<repeated for other VRFs>
suppose we have multiple VRF on the PE(A,B,C) and each of those has a specific IP address
with 1 physical link is it possible we established such that connection between CE and Multiple VRF on PE?
i mean  in which situation we can have multiple
neighbor < ip add VRF GREEN> remote-as 500
neighbor < ip add VRF PINK> remote-as 500
neighbor < ip add VRF BLUE> remote-as 500
on the CE router?
Hello
@cisc0.ameer wrote:
Hello all
CE#router bgp 501
PE#router bgp 500
on the CE router?
Yes it is possible, but you'll need to use vrf enabled sub-interfaces on PE/CE rtrs on the physical interface between them.
Kind Regards
Paul
5 Replies 5
cisc0.ameer
sorry for describing too much
on PE possible i know
but how on the CE
we have just one physical connection ? in 1 physical connection can we established external BGP Peering with multiple IP add of toward his  PE router !!!!!
Hello
@cisc0.ameer wrote:
Hello all
CE#router bgp 501
PE#router bgp 500
on the CE router?
Kind Regards
Paul
Thanks for Your reply
Yes i know sub-interface but the fact is in a Question which i have seen Does Not allow to create Sub-interfaces
this is why i made question on it :( !!!!!!
for PE (suppose we connect that Link to Switch Layer 2
so possible
but CE Router if Doesn't have any Sub-interfaces .....how this problem can be solved ?
yet i'm not reached to an logical solution
If one side router is not having any sub-interface then I don't think there is any possibility without adding any extra device between both devices.
Another solution for you to route-leak between two VRFs
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
so possible
Okay then no sub interface so how do you separate the different networks for the sub interfaces of the PE router you have to the networks active on either a L3 device attached to the PE router - so if you cannot do that then I can see no way to perfrom your request
Kind Regards
Paul
