Cisco 897 VDSL profiles
tomd10
Hello, I am looking for new VDSL modem. I am sick of crappy 20€ solutions, so I found 897. However - I am not sure about it’s max VDSL speed. There should be 35b profile (ISP sells 250 Mbps and it should be real - 250m from DSLAM).
So, what is the max speed for 897VA?
Thanks 😌
Philip D'Ath
We have deployed a large number of Cisco 897's.
If your ISP uses PPPoE it maxs out (aka runs out of CPU) around 160Mb/s.  If your ISP uses DHCP it gets up to around 190Mb/s.  This is when using it with the Gigabit Ethernet WAN port and a typical NAT + firewall configuration.
I'm not sure about 35b profile support.  I don't think we have ever had a customer that close.  The best connection I remember is about 70Mb/s on VDSL.  It definately supports profile 17a.
Note that the Cisco 897 has now been replaced by the 1100 series routers.  I found this document mentioned profile 35b support.
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-7/cisco_1100_series_swcfg_xe_16_7_x/cisco_1100_series_swcfg_xe_16_7_x_chapter_010101.pdf
it depends on what you are running on the router, but with a simple NAT overload configuration, you should be able to get around 500Mbps...
I have found the interesting read below, you might want to have a look:
https://blog.dchidell.com/2016/03/20/cisco-897-tinkering/
Philip D'Ath
Thanks for your detailed answer :).
