Showing results forĀ
Search instead forĀ
Did you mean:Ā
Power cable delivered with IR829-PWR125W-AC ?
ciscoazlancco
Does someone knows what power cord and connector ( AC site ) comes with this power supply ?
CCW isn't mentioning any, nor giving the possibility to select one.
Can't find pictures on the internet to verify visualy ..
This is a separate power supply for the IR829GW-LTE-GA-EK9 .
As this is a router for 'Global' WW use, I can't understand that the cable delivered would fit all worldwide outlets ...
And if there is no cable delivered with the power supply, what kind of connector has the cube ?
Kind regards.
kilianh
The DC/AC adapter comes with an IEC 320-C14 male socket on the AC side. Not sure if a cable is delivered with it as the local wall plug is different in every country. As it is a standard cable there shouldn't be much of a trouble I hope.
Best Regards
Kilian
kilianh
Best Regards
Kilian
Hello Kilianh.
Thanks for your answer !
Now we know at least that these are usable :
CAB-ACR ==> AC Power Cord (Argentina), C13, EL 219 (IRAM 2073), 2.5m
CAB-C15-ISR ==> AC Power Cord (Israel), C15, EL 212 (SI-32), 2.5m
CAB-L620P-C13-US ==> Power Cord, 250VAC, 15A, NEMA L6-20 to C13, US
CAB-ACA-RA ==> Plug,Power Cord,Australian,10A, Right Angle
CAB-ACBZ-12A ==> AC Power Cord (Brazil) 12A/125V BR-3-20 plug up to 12A
CAB-AC-C13-KOR ==> AC Power Cord, Korea, C13, 1.8M
CAB-AC15A-90L-US ==> 15A AC Pwr Cord, left-angle (United States) (bundle option)
CAB-ACBZ-10A ==> AC Power Cord (Brazil) 10A/250V BR-3-10 plug for <10A device
CAB-ACR-RA ==> POWER CORD ARGENTINA, Right Angle
CAB-JPN-RA ==> Power Cord-Japan, Right Angle
CAB-ACI ==> AC Power Cord (Italy), C13, CEI 23-16, 2.5m
CAB-ACC-RA ==> Power Cord China, Right Angle
CAB-L620P-C13-JPN ==> Power Cord, 250VAC, 15A, NEMA L6-20 to C13, JAPAN
CAB-ACU ==> AC Power Cord (UK), C13, BS 1363, 2.5m
CAB-ACC ==> Power Cord - China
CAB-ACS-RA ==> Power Cord, Switzerland, Right Angle
CAB-ACA ==> AC Power Cord (Australia), C13, AS 3112, 2.5m
CAB-ACI-RA ==> Power Cord, Italian, Right Angle
CAB-ACE-RA ==> Power Cord Europe, Right Angle
CAB-ACE ==> AC Power Cord (Europe), C13, CEE 7, 1.5M
CAB-16AWG-AC ==> AC Power cord, 16AWG
CAB-ACSA ==> AC Power Cord (India, South Africa), C13, BS 546, 1.8m
CAB-ACB10A-RA ==> Power Cord, Brazil, Right Angle, 10A
CAB-IND-10A ==> 10A Power cable for India
CAB-C15-CBN ==> Cabinet Jumper Power Cord, 250 VAC 13A, C14-C15 Connectors
CAB-ACU-RA ==> Power Cord UK, Right Angle
CAB-ACS ==> AC Power Cord (Switzerland), C13, IEC 60884-1, 2.5m
CAB-JPN-12A ==> CABASY,POWER CORD,JAPAN 2P, PSE, 12A, 125VAC
These are available from Cisco as spare parts ( a "=" needs to be added at the end of the part code )
Best regards.
