PPOE IPV6
JlassiAhmed0345
HI,
I have configured an  ISR4321 Router as LNS for PPOE IPV6, but I met an issue when I would configured interface virtual-template, I couldn't configure the " ipv6 nd prefix  2001:77::/64 " under the interface virtual-template. is there a solution for this issue?
9 Replies 9
marce1000
                        - Which error do you get when trying this ?
 M.
you mean the 'ipv6 nd prefix' is not available ? What IOS-XE version are you running ? Post the full config of your ISR 4321...
the command "ipv6 nd prefix" work properly, but it cannot allow me to specify the prefix of the nd .
in the configuration below, it shows that there are two  option to choose "default" or "framed-ipv6-prefix"
Router(config)#interface virtual-template 1
Router(config-if)#ipv6 nd prefix ?
  default             Specify prefix default parameters
  framed-ipv6-prefix  Advertise prefix obtained from RADIUS server
odd. What IOS-XE version are you running (sh ver) ?
the current version is 17.02.02
I have experienced a problem with configuring “ipv6 nd prefix  2001:77::/64” under the virtual-template while i was able to configure it under the physical interface. for more information to understand me please check the screens capture enclosed.
the weird thing is, after configuring the line in bold, the address option all of a sudden showed up:
R2(config-if)#ipv6 nd prefix default infinite infinite off-link
X:X:X:X::X/<0-128> IPv6 prefix x:x::y/<z>
Can you try if that works on your router ?
am I try these commands under the interface virtual-template?
if yes, it does not work as it's aspected.
below I share the output of the configured command.
Really odd...it worked one time, not a second time. At least it means that command is there, I'll try and recreate what exactly I did...
