PPP dialing fail
Hi all,
I have a Cisco 1812 with IOS 12.4(15)T17.
I would like to perform pppoe dialing using this device to my ISP. My ISP is using VLAN id 500 for Internet. I configure like below but seem unsuccessful. From the console, I can't even ping to internet.
Please help to analyse.
interface FastEthernet0
description --> WAN
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0.500
encapsulation dot1Q 500
ip address 210.x.x.x 255.255.255.0
no cdp enable
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source route-map nonat interface Dialer1 overload
dialer-list 1 protocol ip permit
5 Replies 5
Hi all,
I perform below command :
debug  ppp authentication
debug  ppp error
debug  ppp negotiation
debug  pppoe events
debug  pppoe errors
debug  pppoe data
debug  pppoe packets
debug  dialer
This is the result. What does it mean???
*Aug 28 06:38:42.175:  padi timer expired
*Aug 28 06:38:42.175:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:38:42.175: pppoe_send_padi:
FF FF FF FF FF FF 00 18 73 07 DD F0 88 63 11 09
00 00 00 0C 01 01 00 00 01 03 00 04 84 CD BB E0 ...
*Aug 28 06:38:51.227: Di1 DDR: Cannot place call, no dialer string set
*Aug 28 06:39:14.431:  padi timer expired
*Aug 28 06:39:14.431:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:39:14.431: pppoe_send_padi:
*Aug 28 06:39:46.695:  padi timer expired
*Aug 28 06:39:46.695:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:39:46.695: pppoe_send_padi:
*Aug 28 06:39:55.227: Di1 DDR: Cannot place call, no dialer string set
*Aug 28 06:40:18.951:  padi timer expired
*Aug 28 06:40:18.951:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:40:18.951: pppoe_send_padi:
kl-warehouse#
*Aug 28 06:40:51.235:  padi timer expired
*Aug 28 06:40:51.235:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:40:51.235: pppoe_send_padi:
*Aug 28 06:40:59.227: Di1 DDR: Cannot place call, no dialer string set
*Aug 28 06:41:23.491:  padi timer expired
*Aug 28 06:41:23.491:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:41:23.491: pppoe_send_padi:
*Aug 28 06:41:55.763:  padi timer expired
*Aug 28 06:41:55.763:  Sending PADI: Interface = FastEthernet0
*Aug 28 06:41:55.763: pppoe_send_padi:
*Aug 28 06:42:03.227: Di1 DDR: Cannot place call, no dialer string set
*Aug 28 06:42:26.043: Di1 DDR: Cannot place call, no dialer string set
*Aug 28 06:42:27.043: Di1 DDR: Cannot place call, no dialer string set
Hi Mohd,
In this case, no dialer string dial-string is configured on the Dialer interface. The router wants to place a call but does not know the number to call. Define a dialer-string:
interface Dialer1
      dialer string 8134
Please rate if it helps.
This is the configuration of Dialer 1 interface. What number does it required??
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ip tcp adjust-mss 1414
ppp authentication chap pap callin
ppp chap hostname keyencekl5@unifibiz
ppp chap password pFThpMgJBVax8
ppp pap sent-username keyencekl5@unifibiz password pFThpMgJBVax8
ppp ipcp dns request accept
ppp ipcp address accept
jus try with dialer string<Phone number with country code> and then try
Hello Mohd,
I am not sure about adding a phone number for this is PPPoE (not DDR related). I found a message here that could be the key to understand the issue:
That means that your router is continuously sending PPPoE Active       Discovery Initiation (PADI) frames to the ISP with no response. If no PPPoE Active Discovery Offer (PADO) is received the PPPoE negotiation will not be successful.
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a7c2.shtml
This behavior can be observed if:
  • the modem is not in bridge mode
  • the provider has a problem and for some reason the DSLAM is not responding at all.
Please turn off all the debugging and activate just:
  • debug pppoe errors
  • debug pppoe events
  • debug ppp negotiation
