PPP Fails in Production Network
Saman Shamim
Hi guys,
This is a real world project. A Cisco 1700  series router will be installed at one location and a ADTRAN 1224R  router will be installed on the other side. I’d like to test it before  installing at client-side by using a Cisco 2800 and the ADTRAN mentioned  above. I made a T1 crossover cable and CD led is green on 1DSU-T1 V2 of  2800.
And of course it’s not working!
- I believe something is wrong with clocking. I used service-module t1 clock source internal command on 2800 to provide clocking and set ADTRAN clocking to Line BUT If I reboot the ADTRAN, while debugging service-module on 2800,  I can see this:
SERVICE_MODULE(Serial0/1/0):Unit has no clock [complete output is below].
And even if I swap clocking sources,  still get the same output on 2800 as above.
- PPP requests sent from either sides are not acknowledged. [output below]
- I get Se0/1/0 PPP: Authorization required every a few seconds on 2800. [output below]
Cisco 2800 (hostname MEE_KC)
1. sh run
username MEE_GF password 0 w1ll0w
interface Serial0/1/0
ip address 100.100.100.1 255.255.255.252
encapsulation ppp
service-module t1 fdl ansi
ppp authentication chap pap
2. sh int s0/1/0
Serial0/1/0 is up,
line protocol is down
Hardware is GT96K with integrated T1 CSU/DSU
Internet address is 100.100.100.1/30
MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
Encapsulation PPP, LCP Listen
, loopback not set
Keepalive set (10 sec)
Last input never, output 00:00:12, output hang never
Last clearing of "show interface" counters 00:15:39
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations  0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
178 packets output, 3382 bytes, 0 underruns
0 output errors, 0 collisions, 17 interface resets
0 unknown protocol drops
3 carrier transitions
DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
3. sh service serial0/1/0
Interface Serial0/1/0
Module type is T1/fractional
Hardware revision is 1.2, Software revision is 20090812,
Image checksum is 0x4346F5, Protocol revision is 0.1
Transmitter is sending remote alarm.
Receiver has loss of signal, loss of frame,
Framing is ESF, Line Code is B8ZS, Current clock source is
internal, Fraction has 24 timeslots (64 Kbits/sec each), Net bandwidth is 1536 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 00:13:18
loss of signal        :    1, current duration 00:01:02
loss of frame         :    1, current duration 00:01:02
AIS alarm             :    0,
Remote alarm          :    1, last occurred 00:13:09
Module access errors  :    0,
Total Data (last 0 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in current interval (796 seconds elapsed):
16671 Line Code Violations, 3 Path Code Violations
0 Slip Secs, 62 Fr Loss Secs, 3 Line Err Secs, 1 Degraded Mins
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 63 Unavail Secs
MEE_KC#Write data 4, cmd 82880600 to B0200014
Msg : 8 (0, 64, 20)
Write data 0, cmd 82888600 to B0200014
Write data 0, cmd 82880600 to B0200014
DEBUGS
1. debug service-module
SERVICE_MODULE(Serial0/1/0): detects loss of signal
SERVICE_MODULE(Serial0/1/0): detects loss of frame
%LINK-3-UPDOWN: Interface Serial0/1/0, changed state to down
SERVICE_MODULE(Serial0/1/0): loss of signal ended after duration 00:01:18
SERVICE_MODULE(Serial0/1/0): loss of frame ended after duration 00:01:18
2.
debug ppp authen
%LINK-3-UPDOWN: Interface Serial0/1/0, changed state to up
Se0/1/0 PPP: Using default call direction
Se0/1/0 PPP: Treating connection as a dedicated line
Se0/1/0 PPP: Session handle[82000002] Session id[2]
3. debug ppp neg
Se0/1/0 LCP: O CONFREQ [REQsent] id 248 len 15
Se0/1/0 LCP:    AuthProto CHAP (0x0305C22305)
Se0/1/0 LCP:    MagicNumber 0x2346C2AD (0x05062346C2AD)
Se0/1/0 LCP: Timeout: State REQsent
Se0/1/0 LCP:O CONFREQ [REQsent] id 249 len 15
Se0/1/0 LCP: State is Listen
ADTRAN 1224R (hostname MEE_GF)
1. sh run
username "MEE_KC" password "w1ll0w"
interface t1 1/1
description 1st T1 to King City
tdm-group 1 timeslots 24 speed 64
no shutdown
interface ppp 1
ip address  100.100.100.2  255.255.255.252
no shutdown
cross-connect 1 t1 1/1 1 ppp 1
2. sh int t1 1/1
t1 1/1 is UP
Description: 1st T1 to King City
Receiver has no alarms
T1 coding is B8ZS, framing is ESF
Clock source is line, FDL type is ANSI
Line build-out is 0dB
No remote loopbacks, No network loopbacks
Acceptance of remote loopback requests enabled
Tx Alarm Enable: rai
Last clearing of counters 00:12:07
loss of frame  : 0
loss of signal : 0
AIS alarm      : 0
Remote alarm   : 1, last occurred 00:12:07
DS0 Status: 123456789012345678901234
-----------------------N
Status Legend: '-' = DS0 is unallocated
'N' = DS0 is dedicated (nailed)
Line Status: -- No Alarms --
5 minute output rate 40 bits/sec, 0 packets/sec
Current Performance Statistics:
0 Errored Seconds, 0 Bursty Errored Seconds
0 Severely Errored Seconds, 0 Severely Errored Frame Seconds
0 Unavailable Seconds, 0 Path Code Violations
0 Line Code Violations, 0 Controlled Slip Seconds
0 Line Errored Seconds, 0 Degraded Minutes
TDM group 1,
line protocol is DOWN
Encapsulation PPP (ppp 1)
136 input errors, 0 CRC, 121 frame
15 abort, 0 discards, 0 overruns
200 packets output, 3800 bytes, 0 underruns
3. sh int ppp 1
ppp 1 is DOWN
Configuration:
Keep-alive is set (10 sec.)
No multilink
MTU = 1500
Authentication protocol is CHAP
IP is configured
Link thru t1 1/1 is DOWN;
LCP state is REQSENT
Receive: bytes=0, pkts=0, errors=0
Transmit: bytes=7828, pkts=412, errors=0
Bundle information
Queueing method: weighted fair
HDLC tx ring limit: 0
Output queue: 0/0/428/64/0 (size/highest/max total/threshold/drops)
Conversations  0/0/256 (active/max active/max total)
Available Bandwidth 48 kilobits/sec
4. debug ppp neg
2011.09.26 08:56:57 PPP.NEGOTIATION PPPtx[t1 1/1] LCP: Conf-Req ID=4 Len=15 AP(CHAP)MAGIC(577b5a40)
Any ideas?
Well played, sir!
interoperability is an illusion.
7 Replies 7
vmiller
Level 7
Level 7
You have no clock source. Make one one device "internal" and the other "line" that will at least make this fake circuit work. You will need to change it when you hook up to the telco
I think I do:
from sh service serial0/1/0 on 2800:
Current clock source is  internal
from sh int t1 1/1 on ADTRAN:
I wonder if something is wrong with the controller for that module. Do you get unit has no clock if you change from internal to line ?
Saman Shamim
Thanks for the reply vmiller.
Here is an update:
I swapped ADTRAN with a 1700 series router and everything worked great between 2800 and 1700. Next, I repalced 2800 with ADTRAN and I saw exact same behavior as above. The ADTRAN doesn't establish a session with its peer. Time to call ADTRAN support?
And I bet if youwent adtran to adtran it would work just fine, or if you had telco in between.
I'd as adtran....see what they say.
Saman Shamim
SOLVED
After being on the line with ADTRAN support for an hour we managed to establish a session without authentication. The reason that it woudn't work before was this:
which now is:
              NNNNNNNNNNNNNNNNNNNNNNNN
But I wasn't still happy. I wanted to use PPP authentication to have a "cool" configuration. And I finally figured it out:
The ppp username and password on ADTRAN routers are not defined as Cisco routers. So if you set username and password as the following it won't work:
MEE_GF(config)#username MEE_KC password w1ll0w
you have to do it under logical ppp interface. Go figure!
MEE_GF(config-ppp 1)#int ppp 1
MEE_GF(config-ppp 1)#username MEE_KC password w1ll0w
Well played, sir!
