09-11-2006 04:15 AM - edited 03-03-2019 01:57 PM
I'm using an AS5300 with an E1/PRI Card with Serial Interfaces (Figure 2-4 : http://www.cisco.com/en/US/products/hw/univgate/ps501/products_installation_guide_chapter09186a008007de67.html#8697) and a Cisco 1721 with a VWIC-2MFT-G703 (http://www.cisco.com/warp/public/788/products/vwicmf_e1.html). I tried to set a multilink connexion between them.
The Problem is that When they are on HDLC encapsulation, both Serial on the AS5300 and the Cisco 1721 are up, but when I set PPP encapsulation on both ends in order to set the multilink, the serial went down.
Following my actual config:
AS 5300:
controller E1 2
framing NO-CRC4
channel-group 0 timeslots 1-31
controller E1 3
framing NO-CRC4
interface Multilink1
ip address 192.168.1.1 255.255.255.252
no cdp enable
ppp multilink
ppp multilink group 1
interface Serial2:0
description LS-1 with Cisco 1721
bandwidth 1984
no ip address
encapsulation ppp
ppp multilink
interface Serial3:0
description LS-2 with Cisco 1721
bandwidth 1984
no ip address
encapsulation ppp
ppp multilink
I tried to reconfigure them on my test Lab with PPP Encapsulation and I always got protocol down, but when using HDLC they goes UP. I also took 2 Cisco 1721 and both of them have VWIC-2MFT-G703, I configure them with PPP Encapsulation and here both ends
goes UP without any problem.
Maybe I misconfigured the AS5300, so if you have an idea about the correct configuration on Cisco 1721 and the AS5300, ie., What should be
done on (Controller and Serial interface) to set PPP multilink?
Following IOS version of the AS5300 and Cisco 1721:
--------- AS5300: ---------
AS5300>sh ver
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(2)XA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Compiled Wed 27-Jun-01 01:27 by hwcheng
Image text-base: 0x600089B0, data-base: 0x61034000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTFLASH: 5300 Software (C5300-BOOT-M), Version 12.0(4)T1, RELEASE SOFTWARE (fc1)
System image file is "flash:c5300-is-mz.122-2.XA.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory.
Processor board ID 24709928
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.2, Item Number 800-2544-04,
Board Revision B0, Serial Number 24709928,
PLD/ISP Version 0.0, Manufacture Date 25-Feb-2001.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
11 Serial network interface(s)
120 terminal line(s)
8 Channelized E1/PRI port(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
--------- Cisco 1721 ---------
Cisco-1721>sh ver
IOS (tm) C1700 Software (C1700-SY-M), Version 12.2(15)T9, RELEASE SOFTWARE (fc2)
Compiled Sat 01-Nov-03 06:27 by ccai
Image text-base: 0x80008120, data-base: 0x80C505CC
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
System image file is "flash:c1700-sy-mz.122-15.T9.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 29145K/3623K bytes of memory.
Processor board ID FOC06160FXN (1631048782), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
2 Serial network interface(s)
2 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
09-11-2006 07:24 AM
What I understand is that when use ppp on 2 interfaces each sides the line protocol goes down. If so..
plz try the followings..
global config..
aaa authentication ppp NO-AUTHENTICATION none
aaa authorization network NO-AUTHENTICATION none
interface command ( all interfaces)
int serial 0 / multilink 0
ppp authorization NO-AUTHENTICATION
PLz let me know..if it works..
Thx,
G
09-11-2006 08:01 AM
I had the same issue. And it turned out,
that it was a software bug. I had to upgrade
the IOS on the AS5300.
HTH,
Andras
09-12-2006 12:42 AM
Thanks gaurav I'll try your configuration and will keep you updated.
Regarding horvaia, could you please tell me which IOS version are you using and solved the problem? which upgrade you did to solve it.
Actually I'm using the C5300-IS-M, Version 12.2(2)XA : c5300-is-mz.122-2.XA.bin
AS5300>sh ver
09-12-2006 01:26 AM
hi,
here is the sh ver
IOS (tm) 5300 Software (C5300-IS-M), Version 12.1(27b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 17:53 by pwade
Image text-base: 0x60008948, data-base: 0x60C36000
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.0(4)T1, RELEASE SOFTWARE (fc1)
"flash:c5300-is-mz.121-27b.bin"
