pppoe cant be removed !
xbaha54321
hi,
i have this configuration:
interface FastEthernet3/0
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 6
pppoe-client dial-pool-number 5
pppoe-client dial-pool-number 4
when i try:
#conf
<config>#int fast3/0
<config-if>#no pppoe-client dialer-pool-number 4
it just wont be removed!
on my other fastethernet intefaces i am able to remove it with the same command
how do i find out what is wrong??
thanks
Cisco IOS Software, 3800 Software (C3845-IPBASE-M), Version 12.4(3d), RELEASE SO
FTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 19-Apr-06 08:56 by alnguyen
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
uptime is 1 hour, 37 minutes
System returned to ROM by reload at 06:25:55 GMT3 Tue Sep 11 2007
System restarted at 06:26:41 GMT3 Tue Sep 11 2007
System image file is "flash:c3845-ipbase-mz.124-3d.bin"
Cisco 3845 (revision 1.0) with 223232K/38912K bytes of memory.
Processor board ID FCZ102770EV
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
2 Token Ring interfaces
8 ATM interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
lgijssel
Level 9
Level 9
Still you have the correct syntax:
To configure a PPP over Ethernet (PPPoE) client and to specify dial-on-demand routing (DDR) functionality, use the pppoe-client dial-pool-number command in either interface configuration mode or ATM virtual circuit configuration mode. To disable any configured functionality, use the no form of this command.
pppoe-client dial-pool-number number [dial-on-demand]
no pppoe-client dial-pool-number number [dial-on-demand]
Can you try if it works when you shutdown the ethernet interface first?
regards,
Leo
hi thanks,
no it wont be removed!
i tried shutting the interface then no pppoe-client dial-pool-number 4, it wont be removed.
i tried no pppoe enable, then all of the dial pools has been removed, but when i enable it again by pppoe enable, all the pppoe-client come back.
help please!
hi, i did some comparision between my 2 fast eth, there is only one diffrence that i found:
Router#sh int fast3/0 switching
FastEthernet3/0
Throttle count 0
Drops RP 0 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 4697 Drops 0
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 126 17234 217 14004
Cache misses 0 - - -
Fast 0 0 163 10938
Auton/SSE 0 0 0 0
Protocol DEC MOP
Process 0 0 230 17710
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 4697 300608 7439 446340
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 0 0 2389 947152
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 0 0 14076 844560
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Router#sh int fast4/0 switching
FastEthernet4/0
Protocol DEC MOP
Process 0 0 116 8932
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol ARP
Process 0 0 9 540
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 0 0 15 4911
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 0 0 6957 417420
Fast 0 0 0 0
Auton/SSE 0 0 0 0
by the way, both fast eth have EXACTLY the same cfg, i am not sure why they are diffrent in this output, might this help? please let me know..
