PPPOE CLIENT CONFIG Question
Charlie Mayes
I have a 2621XM router and I need to config the it for PPPOE for my AT&T service. Will the config below work for me? I only have Fastethernet interfaces on this router. Also where do I type my username and password for the PPPOE login to the internet service.
hostname pooh
ip host rund 172.17.247.195
ip subnet-zero
no ip domain-lookup
vpdn enable
no vpdn logging
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0/0
ip address 10.200.56.22 255.255.255.0
ip nat inside
no ip mroute-cache
interface Ethernet0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip nat outside
ip mtu 1492
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username cisco password cisco1
ip classless
no ip http server
dialer-list 1 protocol ip permit
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 dialer1
access-list 1 permit 10.200.56.0 0.0.0.255
line con 0
exec-timeout 0 0
transport input none
line vty 0 4
login
password ww
Laurent Aubert
If you don't know the authentication protocol your ISP is expecting, configured both (PAP and CHAP)
Also you usually don't authenticate the ISP device so the config should looks like this:
interface Dialer 1
ppp authenticate pap chap callin
ppp chap hostname cisco
ppp chap password cisco1
Replace cisco/cisco1 by your login credentials received from your ISP
Troubleshooting links:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a7c2.shtml#l2
(just replace the ATM interface by your Fast interface)
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a6c3.shtml
Hope this helps
Laurent.
Thanks so much. I will try it and see how it work out.
