PPPoE client on BDI (ASR1K)
CyberNBD
I currently have a PPPoE Client connection on a subinterface, which works fine, but since I need to tie in another interace to it, I would like to change it to a BDI.
Changed the configuration but the PPPoE client won't come up again.  Checked config with this guide https://www.cisco.com/c/dam/en/us/td/docs/routers/asr920/configuration/guide/bbdsl/16-6-1/bba-xe-16-6-1-asr-920.html and also tried switching config from dialer to vt.  No luck on both.
Sub-interface config, which is working fine:
interface GigabitEthernet0/0/3.6
 description INTERNET VLAN
 encapsulation dot1Q 6
 ip tcp adjust-mss 1448
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface Dialer1
 ip address negotiated
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication pap callin
 ppp pap sent-username 1234 password 0 1234
 ip virtual-reassembly
BDI Config and PPPoE not coming up:
 description UPLINK
 no ip address
 no negotiation auto
 service instance 6 ethernet
  encapsulation dot1q 6
  rewrite ingress tag pop 1 symmetric
  l2protocol peer stp
  bridge-domain 6
interface Dialer1
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
interface bdi6
What could I be missing here?
12 Replies 12
M02@rt37
Hello @CyberNBD
Do you have any logs related to the PPPoE connection ?
Best regards
the only thing that shows up in PPPoE debug every 30s or so is:
*Dec 26 15:43:16.164:  padi timer expired
*Dec 26 15:43:16.164:  Sending PADI: Interface = BDI6
*Dec 26 15:43:16.164: pppoe_send_padi:
contiguous pak, size 60
         FF FF FF FF FF FF F4 0F 1B 39 BD 3F 88 63 11 09
         00 00 00 10 01 01 00 00 01 03 00 08 9F 00 00 02
         00 00 24 7E 00 00 00 00 00 00 00 00 00 00 00 00
Try add
 Under service instance of interface not under BDI
MHM
If I put it under the service instance it gets put under the parent interface (0/0/3) and I get the same error messages:
*Dec 26 16:16:34.581:  padi timer expired
*Dec 26 16:16:34.581:  Sending PADI: Interface = GigabitEthernet0/0/3
*Dec 26 16:16:34.581: pppoe_send_padi:
         FF FF FF FF FF FF F4 0F 1B 39 BD 03 88 63 11 09
         00 00 00 10 01 01 00 00 01 03 00 08 5E 00 00 06
         00 00 03 DD 00 00 00 00 00 00 00 00 00 00 00 00
When you use subinterface the pppoe send using vlan tag 6 but with service instance you use pop i.e. the tag is remove
This make pppoe server dont know the traffic.
Remove the rewrite and check
MHM
Removed the "rewrite ingress tag pop 1 symmetric" on the service instance 6 but still same thing.  Also tried enabling PPPoE on the BDI again.
OMG we miss important thing'
pppoe enable <- this for client
pppoe enable group global<- this for server
So since you want router to be pppoe client  then only use first abd dial-pool-num
Note:-check vlan tag as I mention above
MHM
No luck again   Config at this point:
 description UPLINK
 no ip address
 no negotiation auto
 pppoe enable
  l2protocol peer stp
  bridge-domain 6
interface BDI6
 no ip address
and also tried putting it under the BDI again:
 description UPLINK
 no ip address
 no negotiation auto
  l2protocol peer stp
  bridge-domain 6
interface BDI6
 no ip address
 pppoe enable
Dialer 1 config remains unchanged from original post.
Can you share
Show ethernet service instance detial
Show interface bdi 6
MHM
Show ethernet service instance detail:
Service Instance ID: 82
Service Instance Type: Static
Description: PUBIP
Associated Interface: GigabitEthernet0/0/0
Associated EVC:
L2protocol peer stp
CE-Vlans:
Encapsulation: dot1q 82 vlan protocol type 0x8100
Rewrite: ingress tag pop 1 symmetric
Interface Dot1q Tunnel Ethertype: 0x8100
State: Up
EFP Statistics:
   Pkts In   Bytes In   Pkts Out  Bytes Out
    466155   35695235     158112   15563249
EFP Microblocks:
Microblock type: Bridge-domain
Bridge-domain: 82
Microblock type: L2Mcast
L2 Multicast GID: 1
Microblock type: dhcp_snoop
L2 Multicast GID: 1
Description: PUBIP
Associated Interface: GigabitEthernet0/0/1
Associated EVC:
L2protocol peer stp
CE-Vlans:
State: Up
EFP Statistics:
    532557   45622600          0          0
EFP Microblocks:
Bridge-domain: 82
L2 Multicast GID: 2
L2 Multicast GID: 2
Service Instance ID: 4
Description: TV VLAN
Associated Interface: GigabitEthernet0/0/3
Associated EVC:
L2protocol peer stp
CE-Vlans:
Encapsulation: dot1q 4 vlan protocol type 0x8100
State: Up
EFP Statistics:
      1374      89004       1374      83360
EFP Microblocks:
Bridge-domain: 4
L2 Multicast GID: 1
L2 Multicast GID: 1
Service Instance ID: 6
Description: INTERNET VLAN
Associated EVC:
L2protocol peer stp
CE-Vlans:
Encapsulation: dot1q 6 vlan protocol type 0x8100
State: Up
EFP Statistics:
         0          0          0          0
EFP Microblocks:
Bridge-domain: 6
L2 Multicast GID: 1
L2 Multicast GID: 1
Associated Interface: GigabitEthernet0/1/0
Associated EVC:
L2protocol peer stp
CE-Vlans:
State: Up
EFP Statistics:
      1374      83360       1374      89004
EFP Microblocks:
Bridge-domain: 4
L2 Multicast GID: 2
L2 Multicast GID: 2
Show interface bdi 6:
BDI6 is up, line protocol is up
  Hardware is BDI, address is f40f.1b39.bd3f (bia f40f.1b39.bd3f)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Last input never, output 00:00:18, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     30 packets output, 1834 bytes, 0 underruns
     0 output errors, 0 interface resets
     0 unknown protocol drops
Associated EVC:
L2protocol peer stp
CE-Vlans:
State: Up
EFP Statistics:
         0          0          0          0
there is no packet Out or In in this service instance
are the port g0/0/3 is UP/UP?
MHM
Yeah I noticed that too.  gi0/0/3 is UP/UP
