Bookmark
Subscribe
863
PPPoE not working in packet tracer
calvinshuen
HI guy, I am configuring both the R2 and R3 to set up PPPoE between them. After I apply the script below for R2 and R3. Both routers lost connective and the R3 routing table became empty. Is there any problem with the script below? Thanks for help?
R2 configuration
aaa new-model
aaa authentication ppp default local
username tafe password class
ip local pool TAFEPOOL 10.0.40.1 10.0.40.10
interface virtual-template 1
ip unnumbered FastEthernet0/1
peer default ip address pool TAFEPOOL
ppp authentication chap
exit
bba-group pppoe global
virtual-template 1
exit
interface f0/1
no ip add
pppoe enable group global
no shutdown
R3 configuration
aaa new-model
interface f0/1
no ip address
pppoe enable
pppoe-client dial-pool-number 1
exit
interface dialer 1
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 1
ppp chap hostname tafe
ppp chap password class
exit
no ip route 0.0.0.0 0.0.0.0 10.0.40.1
ip route 0.0.0.0 0.0.0.0 dialer 1
interface f0/1
no shutdown
6 Replies 6
marce1000
   -  FYI : Community group for Packet Tracer project questions
 M.
I dont remember the command but I think is
Dialer group x
This command make interface try pppoe when there is interest traffic pass
Check this point
MHM
Also you need dialer list.
MHM
Blue_Bird
Hello calvinshuen,
Also..Please go through the sample configuration...it might helpful...
Best regards
******* If This Helps, Please Rate *******
post your zipped Packet Tracer project (.pkt) file..
There you go. Thanks:)
