PPPoE over ADSL "PPPoE: No session found" error
denzilstephens
Hi all,
I am trying to configure PPPoE over ADSL but the PPPoE session is not coming up. I am receiving the following from PPPoE debug:
Jul  7 23:18:11.691:  padi timer expired
Jul  7 23:18:11.691: Sending PADI: vc=0/38
Jul  7 23:18:11.711: PPPoE 0: I PADO  R:8843.e19d.461b L:0019.5539.28ac 0/38  ATM0/1/0.38
Jul  7 23:18:11.711: PPPoE: No session found
router#show pppoe session
     1 client session
Uniq ID  PPPoE  RemMAC          Port                  Source   VA         State
           SID  LocMAC                                         VA-st
    N/A      0  0000.0000.0000  ATM0/1/0.38           Di1      N/A        PADISNT
                0000.0000.0000  VC:  0/38
interface ATM0/1/0
description ADSL2
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
bundle-enable
interface ATM0/1/0.38 point-to-point
atm route-bridged ip
pvc 0/38
  oam-pvc 0
  pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1486
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp chap hostname hostname
ppp chap password 0 password
ppp pap sent-username hostname password 0 password
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
Any idea what the issue might be. Any help would be very much appreciated.
6 Replies 6
Peter Paluch
Hello Denzil,
No exact idea as to what exactly might be your problem, but let's try starting with removing unnecessary commands and seeing if that has a positive effect:
  • Remove the bundle-enable from your ATM0/1/0 interface
  • Remove the atm route-bridged ip from your ATM0/1/0.38 subinterface
If that does not help please include the full output from the following debugs (activated simultaneously):
debug pppoe errors
debug pppoe events
debug pppoe packets
Thank you!
Best regards,
Peter
Thanks Peter,
I have removed those two lines of config.
This is the full output of the three debug commands:
Jul  7 23:37:35.703:  padi timer expired
Jul  7 23:37:35.703: Sending PADI: vc=0/38
Jul  7 23:37:35.703: pppoe_send_padi:
         00 01 09 00 AA AA 03 00 80 C2 00 07 00 00 FF FF
         FF FF FF FF 00 19 55 39 28 AC 88 63 11 09 00 00 ...
Jul  7 23:37:35.723: PPPoE 0: I PADO  R:8843.e19d.461b L:0019.5539.28ac 0/38  ATM0/1/0.38
         00 19 55 39 28 AC 88 43 E1 9D 46 1B 88 63 11 07
         00 00 00 70 01 05 00 38 00 00 0D E9 01 19 74 ...
Jul  7 23:37:35.723: PPPoE: No session found
Denzil,
Hmm, that's strange. What is the exact router's type and IOS version please? Do you have another ADSL modem/router to try to connect to the very same line and see whether it is able to connect successfully?
Best regards,
Peter
c1841-advipservicesk9-mz.124-24.T5.bin
HWIC-1ADSL-M
I have also run debug on the core router and receive:
Jul 24 22:59:40.533: PPPoE 0: I PADI  R:0019.5539.28ac L:ffff.ffff.ffff 600 Gi0/0.600
Jul 24 22:59:40.533:  Service tag: NULL Tag
Jul 24 22:59:40.533: PPPoE 0: O PADO, R:8843.e19d.461b L:0019.5539.28ac 600 Gi0/0.600
I am also starting to wonder if the hardware/IOS don't work together.
Many thanks again Peter
Hello Denzil,
Do you have an option of capturing the traffic exchanged between the 1841 and your core router? Having a close look at the PPPoE packets could reveal more what is going on. The debugs use only abbreviated output which does not contain the entire packet contents.
Best regards,
Peter
Ok thanks Peter, will see what i can do.
