CBAC filter issue
thiru.vel10
Level 5
Level 5
Hi All,
I am Thiru, I am observing internet disconnection issue while using the CBAC filter. Without CBAC filter internet is working fine without issue, When i am configuring the CBAC filter i am getting disconnection from the internet web server. Issue in on and off. and also i am getting some erro.
ip inspect name myfw tcp
ip inspect name myfw udp
ip inspect name myfw realaudio
ip inspect name myfw smtp
ip inspect name myfw streamworks
ip inspect name myfw vdolive
ip inspect name myfw tftp
ip inspect name myfw rcmd
ip inspect name myfw ftp
ip inspect name myfw http
ACL
access-list 100 remark --> CBAC security
access-list 100 permit gre any any
access-list 100 permit esp any any
access-list 100 permit udp any any eq isakmp
access-list 100 permit udp any eq isakmp any
access-list 100 permit udp any eq ntp any eq ntp
access-list 100 permit udp any host    (wanip)  eq 10000
access-list 100 permit icmp any any echo-reply
WAN INterface ,
IP inspect myfw out
ip access-group 100 in
Dropping TCP Segment: seq:1439898881 1476 bytes is out-of-order; expected seq:1439883073. Reason: TCP reassembly queue overflow - sessio
Can someone can hellp me out this issue
I am using cisco 1841 and IOS :   AdvanceIPservice 12.4 T9
6 Replies 6
thiru.vel10
Level 5
Level 5
Hi All,
Anyone can help me out here ??
Hi thru,
can you this.
access-list 100 permit tcp any any eq www
access-list 100 permit udp any any eq domain
ip inspect name myfw http alert on audit-trail on
res
paul
Kind Regards
Paul
Hi Paul ,
Thanks for your prompt response.
I am managing more than 50 Internet routers and I have configured the CBAC filter with Websense in cisco 1721, 1841 , 1941 & 2811. I am keeping same configuration in the all device for standard.
I will add this two line in Inbond ACL and update you the status.
  Thiru
Hi Paul ,
I have configured the request rule in the my outbond ACL. However still i am observing the log message.
ue overflow - session *.*.*.*.164:3236 to 152.111.191.11:80
Jul 25 14:50:12.890 GMT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3349648696
540 bytes is out-of-order; expected seq:3349634852. Reason: TCP reassembly queu
Jul 25 14:50:14.382 GMT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3349645812
1476 bytes is out-of-order; expected seq:3349634852. Reason: TCP reassembly que
Jul 25 14:50:20.909 GMT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:29819585 1
476 bytes is out-of-order; expected seq:29808852. Reason: TCP reassembly queue o
verflow - session *.*.*.*.164:3240 to 152.111.191.11:80
Jul 25 14:50:22.637 GMT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:29819585 1
Jul 25 14:50:24.933 GMT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:29822469 3
73 bytes is out-of-order; expected seq:29808852. Reason: TCP reassembly queue ov
Jul 25 14:50:26.352 GMT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:29819585 1
Thiru
Hi Thiru,
See the below sample config may help you....
aaa new-model
aaa authentication login default local
ip inspect name my_firewall ftp timeout 3600
ip inspect name my_firewall smtp timeout 3600
ip inspect name my_firewall udp timeout 15
ip inspect name my_firewall tcp timeout 3600
interface FastEthernet0/0
description Inside of Network
ip address 192.168.150.1 255.255.255.0
interface FastEthernet0/1
description Outside of network
ip address
ip access-group OUTSIDE_IN in
ip inspect name my_firewall out
ip nat inside source list NAT interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0
no ip http server
no ip http secure-server
line con 0
logging sync
line vty 0 15
trans input ssh
logging sync
ip access-list extended NAT
permit ip 192.168.150.0 0.0.0.255 any
ip access-list extended OUTSIDE_IN
deny   ip host 0.0.0.0 any
deny   ip 127.0.0.0 0.255.255.255 any
deny   ip 192.0.2.0 0.0.0.255 any
deny   ip 224.0.0.0 31.255.255.255 any
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.168.0.0 0.0.255.255 any
permit icmp any any time-exceeded
deny   ip any any
crypto key gen rsa general-keys mod 1024
Please rate the helpfull posts.
Naidu.
aaa new-model
ip address
ip classless
no ip http server
line con 0
logging sync
line vty 0 15
trans input ssh
logging sync
deny   ip any any
Naidu.
Hi thiru,
access-list 100 deny tcp any any
access-list 100 deny udp any any
access-list 100 permit icmp any any time-exceeded
access-list 100 permit icmp any any packet-too-big
access-list 100 permit icmp any any traceroute
access-list 100 permit icmp any any unreachable
access-list 100 permit icmp any any reassembly-timeout
access-list 100 deny ip any any
res
Paul
Kind Regards
Paul
