When connected to a DSL service provider with a Cisco router using a dialer's basic configuration as follow:
interface Dialer1
ip address negotiated
[OUTPUT_OMITTED]
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
ppp authentication pap chap callin
ppp chap hostname [OUTPUT_OMITTED]
ppp chap password 0 [OUTPUT_OMITTED]
ppp pap sent-username [OUTPUT_OMITTED] password 0 [OUTPUT_OMITTED]
Is there a way to see whcich authentication protocol (PAP, CHAP...) has been used other than running a debug ppp authentication while authenticating ?
Thank you.
Vivien F.
Solved! Go to Solution.
There is no way beside using debiug command. Note for PPPoE you do not need:
dialer persistent
dialer persistent
Ok thank you very much for the prompt answer.
Merry Christmas.
Thank you for the nice rating and good luck!
