PPPoe support to cisco 3750 switch
Yasmeen
Hi team,
           Cisco 3750 switch can support - PPPoe configuration,
  •  If yes means pls share me the commands to configure
  • If no means pls tel me the PPOe configuration supported switches series with commands
thanks
regards,
Yasmeen Shaul Hameed.
balaji.bandi
Catalyst 3750 does not support PPPoE. The PPPoE support is typical for ROUTER.
here is the feature navigator :
https://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
BB
Giuseppe Larosa
Hello Yasmeen,
as explained by other colleague PPPoE client feature is supported only on routers and not on multilayer switches like the C3750.
Multilayer switches are appropriated for metro ethernet access as they are able to support sub-rate links.
PPPoE client is available on routers.
Hope to help
Giuseppe
thank u so much for quick reply ... Giuseppe Larosa
