PPPOE username
engebrsb17
                   I am attempting to bring up a remote router using a pppoe connection by replacing the current Tenda 308R router with a Cisco 1921 using the ethernet connection on the WAN side.  The connection works fine with the Tenda in place but when I put the Cisco in I get no connection and no answer for my PADI queries.
I always get padi timer expired.  The error and config is below, Any Ideas?  I do not think it is even getting to the ppp authentication.
000832: *Oct 16 18:55:13 Bulg: pppoe_send_padi:
contiguous pak, size 60
         FF FF FF FF FF FF A4 4C 11 CE 3E C0 88 63 11 09
         00 00 00 10 01 01 00 00 01 03 00 08 97 00 00 02
         00 00 11 31 00 00 00 00 00 00 00 00 00 00 00 00
000833: *Oct 16 18:55:46 Bulg:  padi timer expired
current config
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
bandwidth 1000
ip address 1.1.1.1  255.255.255.0
ip mtu 1492
ip nat outside
ip inspect DEFAULT100 out
no ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1300
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname sfb
ppp chap password 7 095F5B07161503130D030B2E38
ppp pap sent-username sfb password 7 04481E080031584F0F160A1301
end
paolo bevilacqua
Keep circuit off for a while, or call ISP, they may have a lock or cache to the other router MAC address.
Otherwise you could try setting that MAC address on g0/0 as well.
Note, adjust-mss adjust should be 1452, not 1300. And pppoe enable is not needed.
For good performances, avoid 'ip inspect'.
5 Replies 5
nickbonifacio
Hi Steve,
it sounds like the other side is not responding.
Also, you are sending pap and chap.. which authentication is the other side using?
Can you do:
debug ppp authentication
debug pppoe errors
debug pppoe events
debug ppp negotiation
As a last resort, I would do "dialer persistant" under the Dialer config.
Nick Bonifacio CCIE #38473
paolo bevilacqua
engebrsb17
I will leave the connection open for 5 minutes and see if that produces any better results.  I have enabled the debugs but there is no information, i suspect this is because the padi never completes.
Hi Steve,
Paolo brings up a good point and I have actually had this happen to me.  The ISPs like to hold on to those macs for a long time, and in some instances they will even sticky them to the port.  You might want to call them and tell them you are changing out devices.
Nick
engebrsb17
Thanks for the tip Paolo.  As soon as the ISP released the MAC the circuit came up.
