pre and post compression image sizes disagree
kstanley
Cisco 3745
I am upgrading the DRAM. If I put in 1 256 module it boots up fine with no error. If I install 2 256 DRAM modules I get the above error.
I have installed 2 256 DRAM modules before in a few other 3745 with not problems.
Any suggestions?
smothuku
Level 7
Level 7
Hi ,
What is the exact error you are getting while installing DRAM modules.
satish
