Prevent Inter-vlan routing
rasoftware
Hi all,
I am using a 3550 for layer 3 routing to allow all VLANs to use a common firewall. Basically VLANs are 10.1.0.0/16, 10.2.0.0/16 and so on and port 172.16.0.0/16 which is in the firewalls subnet. I want all VLANs to be able to access the firewall but no allow the client VLANs to access each other. Do I need to do this with ACLs? I would like the setup as simple as possible.
9 Replies 9
Roberto Salazar
Level 8
Level 8
Yes, you will need an ACL that will prevent vlan 10.1 from talking to vlan 10.2 and vise versa. It's a simple Access-list, for example:
access-list 1 deny 10.2.0.0 0.0.255.255
access-list 2 deny 10.1.0.0 0.0.255.255
interface vlan 1
ip access-group 2 out >> will prevent any traffic from 10.2.0.0
interface vlan 2
ip access-group 1 out >> will prevent any traffic fomr 10.1.0.0
Please rate helpful post.
hi would this work also?
access-list 101 permit ip any any
access-list 101 deny ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
interface vlan x
access-group 101 out
ie stop and 10.0.0.0 accessing any other?
I do not see any reason why it would not work but have the deny first before the permit.
Please rate helpful posts.
vlan x
ip access-group 1010 out
This prevents a host in 10.14.0.0/16 pinging a host in 10.15.0.0/16.
However I am still able to ping 10.15.0.1 (vlan15 IP) from 10.14.0.0/16
10.15.0.1 is the IP assigned to the VLAN associated with the interface. These address act as the default gw for the clients. No sure how this is possible.
HI
From where u r trying to ping this IP.r u pigning it from any hosts or from the router itself.
mahmood
Hi if I ping from the host I am able to ping the other VLAN GW IPs but not any host in those networks.
Can u check applying this access-list inbound and verify wearther u r able to ping the G/W address.
Mahmood
Hi if I apply in "in" as well as "out" I cannot the ping any VLAN GW.
I can access internet etc ok though via this port.
This is probably ok but it would be nice to ping the local GW from its respective VLAN.
Do you guys think this is feasible solution when a person have more than 20 VLANS and only wants all to communicate with 1 VLAN fully and 19 others doesn't needs to communicated with each other.
Although in my case i have 4506, still i have'nt proceeded as ACL's will put a load on the CPU . Any idea ?
thanks,
Shakeel Ahmad
