PRI RAI Message
Hi All,
I need some help please, we have a client with a telco PRI, the telco had a failure last week but has since resolved but ever since then when we make an outbound call, the call lasts for about 2-3 seconds and then shuts itself down(inbound is fine), not sure what else to check as this configuration has been running for more than 6 years, PRI is registered to CUCM via MGCP, I have attached debug isdn q931 error on a failed call. Telco has tested with a trend device and are able to make calls successfully from the PRI. I can attach the configuration if required.
J
10 Replies 10
Georg Pauwen
try and toggle the CRC4 settings on the controller interface (Framing NO-CRC4/Framing-CRC4)...
RAI means Remote Alarm Indication by the way, usually indicating a problem at the remote end.
Which isdn switch-type do you have configured for your PRI ?
Thanks for your reply, we have tried that but no joy, what i did notice now is that the PRI still flaps with that message even though no outbound calls are being routed through it, I am pretty sure this is telco related but they have cleared their side and the fact that they can dial out when they connect to the PRI is even more frustrating. PRI Configuration is below and log error.
interface Serial0/0/1:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn overlap-receiving
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 isdn send-alerting
 isdn sending-complete
 no cdp enable
Jul 24 08:11:14.817: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to down (RAI detected)
Jul 24 08:11:15.065: %MARS_NETCLK-3-HOLDOVER: Entering Holdover for Controller E1 0/0/1
Jul 24 08:11:16.817: %LINK-3-UPDOWN: Interface Serial0/0/1:15, changed state to down
Jul 24 08:11:18.817: %CONTROLLER-5-UPDOWN: Controller E1 0/0/1, changed state to up
Jul 24 08:11:20.817: %LINK-3-UPDOWN: Interface Serial0/0/1:15, changed state to up
Jul 24 08:11:21.317: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/1
can you post the full config of your router ? Which country are you in, and who is your ISP ?
could be a physical (cabling) problem...
Can you post the output of 'show controllers e1'...
can you check the status of your network clock configuration ?
show netw
should tell you if your E1 clock state is 'good'...
COR-EDEN-VG01#show network-clocks
Network Clock Configuration
Priority Clock Source Clock State Clock Type
1 E1 0/0/0 LINK DOWN E1
2 E1 0/0/1 GOOD E1
10 Backplane GOOD PLL
Current Primary Clock Source
2 E1 0/0/1 GOOD E1
what are your options for the clock on the E1 controller in slot 0/0/0 ?
Can you configure 'clock source line' ?
Looks like i can, should i try it ?
[cid:image001.png@01D4236E.2F3404E0]
You have no link on that line anyway, so try and configure that...
Tried that but i can try again. I am in South Africa and telco provider is Telkom. Configuration below
Current configuration : 5924 bytes
version 15.1
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
clock timezone gmt 2 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip name-server X.X.X.X
voice-card 0
 dspfarm
 dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 h245-address on-connect
 sip
  early-offer forced
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
license udi pid CISCO2921/K9 sn FGL161910E1
hw-module pvdm 0/0
hw-module sm 1
redundancy
controller E1 0/0/0
 pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description Link to Edenvale LAN
 ip address X.X.X.X X.X.X.X
 ip flow ingress
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn send-alerting
 no cdp enable
 no ip address
 encapsulation hdlc
 isdn send-alerting
 no cdp enable
interface SM1/0
 ip unnumbered GigabitEthernet0/0
 service-module ip address X.X.X.X X.X.X.X
 !Application: CUE Running on SM
 service-module ip default-gateway X.X.X.X
interface SM1/1
 description Internal switch interface connected to Service Module
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route X.X.X.X X.X.X.X SM1/0
control-plane
voice-port 0/0/0:15
 echo-cancel coverage 64
 cptone ZA
voice-port 0/0/1:15
 cptone ZA
ccm-manager fallback-mgcp
ccm-manager redundant-host X.X.X.X X.X.X.X
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server X.X.X.X X.X.X.X
ccm-manager config
ccm-manager download-tones
mgcp
mgcp call-agent X.X.X.X 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm X.X.X.X identifier 1 priority 1 version 7.0
sccp ccm X.X.X.X identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register EDENTRN
 associate profile 2 register EDENCFB
 associate profile 3 register EDENMTP
 keepalive retries 5
 switchover method immediate
 switchback method graceful
 switchback interval 15
 signaling dscp af31
dspfarm profile 1 transcode
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 4
 associate application SCCP
dspfarm profile 2 conference
 codec g729r8
 codec g711alaw
 codec g711ulaw
 maximum sessions 8
dspfarm profile 3 mtp
 codec g711ulaw
 maximum sessions software 250
dial-peer voice 100 voip
 description Voicemail (CUE) System
 destination-pattern 28899
 session protocol sipv2
 session target ipv4:X.X.X.X
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address X.X.X.X port 2000
 max-ephones 110
 max-dn 200 dual-line no-reg
line con 0
 logging synchronous
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input all
line vty 5 15
 logging synchronous
 login local
 transport input all
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp master
ntp update-calendar
end
