pri
amenash123
hi
i have that configuration:
hostname Center-2
logging buffered 10000 debugging
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login no_tacacs local enable
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
enable secret xxxx
enable password xxxx
username xxx password xxx
ip subnet-zero
ip telnet hidden addresses
no ip domain-looku
no ip bootp server
isdn switch-type primary-net5
call rsvp-sync
controller E1 0/0
channel-group 1 timeslots 1-31
controller E1 1/0
pri-group timeslots 1-31
interface Loopback0
ip address 188.10.x.x.x.255.255
interface Ethernet0/0
ip address 12.x.x.x.255.0.0
ip rip send version 1 2
ip rip receive version 1 2
full-duplex
bridge-group 10
interface TokenRing0/0
no ip address
shutdown
ring-speed 16
interface Serial1/0:15
no ip address
encapsulation ppp
ip mroute-cache
dialer pool-member 1
no cdp enable
interface Dialer1
ip address 194.106.11.1 255.255.255.0
encapsulation ppp
dialer in-band
dialer string 7105088
dialer load-threshold 20 either
dialer-group 1
no cdp enable
ppp multilink
interface Dialer2
ip unnumbered Ethernet0/0
ip rip send version 2
ip rip receive version 2
encapsulation ppp
dialer pool 1
dialer idle-timeout 240
dialer-group 2
no cdp enable
ppp authentication chap
ppp multilink
router rip
version 2
redistribute connected
redistribute static
passive-interface Dialer2
passive-interface Loopback0
network 10.0.0.0
network 11.0.0.0
network 12.0.0.0
network 192.168.3.0
network 192.168.93.0
no auto-summary
ip classless
ip route 0.0.0.0 0.x.x.x.0.0.3
ip tacacs source-interface Ethernet0/0
no ip http server
logging source-interface Ethernet0/0
access-list 9 permit 172.30.98.51
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
bridge 10 protocol ieee
dial-peer cor custom
Center-2#
this is a center router that need to called about 8 calls from brunch on isdn,
and the problem is that only one call can be success and the second fail and when i disconnect success call then the second success to connet.there only one connent at the same time,why?
rais.ahmad
Is channel 15 your D-channel? Dialer1 doesn't belong to any pool?
Thanks.
but my serial1/0:15 collects the calls.
it get the calls,is it?
If you use dialer pool's you can only terminate one call per dialer interface and that is why you are having the issue. If you want to terminate more than one call you would need to configure more dialer interfaces.
But to make things easier you can just change the serial interface to use a rotary group instead of dialer pool.
dialer rotary-group x (where x is the dialer interface number)
Daniel
that configuration is good?
dialer rotary-group 1
encapsulation ppp
dialer pool 1
dialer-group 2
no cdp enable
ppp multilink
