SHDSL help required
hi all
i want to connect 2 different offices distance is around 800mts, i have 2 pair(4 wire) copper cable from one office to another i would like to use G.SHDSL using 1841 routers.i want to deploy these cards in back to back fashion. kindly post your suggetions.
Regds
Binoy.
Hello Binoy,
basically, you will need to configure one of your routers as CO, and the other as CPE.
Have a look at the following document, it has sample configs for the back-to-back setup. Although 828 and 2612 routers are used in this example, the setup should work with 1841 routers as well:
Configuring CPE Back-to-Back Through G.SHDSL Ports
http://www.cisco.com/warp/public/794/dsl_cpe_config.html
HTH,
GP
hi GP thanks for your input.
ok configuration part is ok.is there any bottleneck,i mean any technical issues you can see in this.
Regds
Binoy.
