Prime 3.1 interface bandwidth
Mark Schwartz
All,
Brand new installation of Prime 3.1.
All WAN routers are ISR 4321's (26 of them).
Customer has internet pipes at each branch ranging from 10 MB to 50 MB.
Routers have 1 GB interfaces.
Prime is reporting very low interface utilization.  This makes sense since the internet pipe is anywhere from 10 MB to 50 MB against
a 1GB physical link.
They want to know how can Prime display 100% usage on the link if a 10 MB link at a location really is being fully used.
If I issue the 'bandwidth' command under the WAN interface will Prime report usage off of the set (bandwidth xxx) value or does
it still report against the physical interface?
Bottom line is how do I get Prime to display % of bandwidth used against the internet bandwidth at each location, not the routers
physical interface.
Thank you.
0 Replies 0
