Problem booting the ISR 4451
I have a CISCO 4451 and i'm not able to boot it , it boot always in ROMMON mode:
i have tried to boot from USB and TFTP i always get the message bellow despite that i downloded the IOS from cisco web site :
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated 10ee866e:e151d5ce:7ca1fd68:16f70e7f:dfb8fc12
expected e1fdef2a:97c69364:089e39e4:67ec9c7d:8ad4e84a
SHA-1 hash doesn't match
boot: error executing "boot usb0:
rommon 1 > showmon
Current image running (0/1): Boot ROM0
System Bootstrap, Version 15.4(3r)S, RELEASE SOFTWARE
Copyright (c) 1994-2014 by cisco Systems, Inc.
12 Replies 12
you might be hitting the following bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCto91590/?referring_site=bugquickviewredir
hi gpauwen
Thanks for your answer but my file size is 436 Mo
what is the fulll image name ? I want to check the original file size in the Cisco download section....
this one for exemple :
Cisco ISR 4400 Series IOS XE Universal
isr4400-universalk9.03.13.06a.S.154-3.S6a-ext.SPA.bin size :408.06 MB
Leo Laohoo
Uhhhh ...
If the boot variable string points to USB, is there actually a USB flash drive in USB port 0?
of course !!!! it's just that i didn't mention the IOS name :)
if the usb drive was not plugged it will show " media drive usb: not present "
There is nothing wrong with the syntax.
There can only be two main reason why the router won't boot from USB, and they are:
1.  Either the file is missing or incorrect; or
2.  The USB flash is not supported.
Plug a console cable and reboot the router.  I want to see the entire boot-up process.  This error message is disturbing.
It cannot boot from USB, TFTP and event from the bootflash.
it always show : SHA-1 hash doesn't match
What is the config-registry value?  0x2142?
i have tried the 0x2141 and the 0x0
The correct value, for a router, should be 0x2102.
In Fact the problem was in the flash memory.
i have put it in a PC , format it and then boom it works.
