Problem configuring ipsec VPN
M Talha
hello everyone,
Well i am having problem configuring ipsec VPN and getting this error.
Plz help and let me know how i can resolve this issue and configure ipsec vpn on my cisco 2801 router.
wait for reply
INS-PAK#sh ver
Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.4(16b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 20-Dec-07 03:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
INS-PAK uptime is 1 week, 4 days, 8 hours, 50 minutes
System returned to ROM by reload at 07:35:19 UTC Thu Aug 15 2013
System image file is "flash:c2801-ipbase-mz.124-16b.bin"
Cisco 2801 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ12141015
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
INS-PAK#
INS-PAK#
INS-PAK#config t
Enter configuration commands, one per line.  End with CNTL/Z.
INS-PAK(config)#cry
INS-PAK(config)#cryp
INS-PAK(config)#crypto
INS-PAK(config)#crypto isa
INS-PAK(config)#crypto isakmp policy 10
% Invalid input detected at '^' marker.
INS-PAK(config)#
INS-PAK#
Edison Ortiz
You have the wrong image loaded. You have IP Base while Security or IP Services feature set is required for IPSEC.
Edison Ortiz
I hope one of these will work. Rigth Edison..!
ADVANCED SECURITY Service Contract Required
c2801-advsecurityk9-mz.124-24.T7.bin
or
ADVANCED IP SERVICESService Contract Required
c2801-advipservicesk9-mz.124-24.T7.bin
Yes, either one will work - thanks for the rating and good luck
