Problem in ASR-903 Upgrade - ' .rommon_upgrade/rommon.bin no found'
Diego_S
Hello community,
I'm facing the following problem, I appreciate if you can help me.
I am upgrading ROMMON from an ASR-903 from version 15.6(43r)S to 15.6(48r)S. and the following process was carried out:
ASR-903#upgrade rom-monitor filename bootflash:IOS-3.18.8aSP/asr900_15_6_48r_s_rommon.pkg all
Upgrade rom-monitor on Route-Processor 0
Target copying rom-monitor image file
Checking upgrade image...
1966080+0 records in
3840+0 records out
Upgrade image MD5 signature is
Burning upgrade partition...
1966080+0 records out
Checking upgrade partition...
Upgrade flash partition MD5 signature is
ROMMON upgrade complete.
To make the new ROMMON permanent, you must restart the RP.
ASR-903#sh pla
ASR-903#sh platform
Chassis type: ASR-903
Slot Type State Insert time (ago)
0/0 A900-IMA2Z ok 00:02:57
0/1 A900-IMA2Z ok 00:02:56
0/3 A900-IMA8S ok 00:02:55
0/4 A900-IMA8S ok 00:02:55
R0 A900-RSP2A-64 ok, active 00:05:11
F0 ok, active 00:05:11
P0 A900-PWR550-A ok 00:04:29
P1 A900-PWR550-A ok 00:04:27
P2 A903-FAN-E ok 00:04:24
Slot CPLD Version Firmware Version
R0 1905200E 15.6(43r)S
F0 1905200E 15.6(43r)S
ASR-903#wr
Building configuration...
[OK]!
ASR-903#reload
Proceed with reload? [confirm]
Aug 27 00:39:39.906 R0/0: %PMAN-5-EXI
System Bootstrap, Version 15.6(43r)S, RELEASE SOFTWARE (fc1)
Technical Support: https://protect-eu.mimecast.com/s/5ODNCGZ1ou0gDDWluY_Dse?domain=cisco.com
Copyright (c) 2020 by cisco Systems, Inc.
Compiled Mon 18-May-20 03:52 by pallavik
Initializing the PCI..
PCIe link training done..FPGA vendor ID[0x5f1137]
pci configuration done..
RSP2-64 P2 Board(1200 MHz). FPGA-325T
Current image running: Boot ROM0
Last reset cause: RSP-Board
Rommon upgrade requested
Directory .rommon_upgrade/rommon.bin not found
Unable to locate .rommon_upgrade/rommon.bin directory
Unable to load .rommon_upgrade/rommon.bin
Failed to upgrade ROMMON
Configuring zarlink...
Cylon-1 vendor ID[0x5e1137]
Cylon-2 vendor ID[0xffffffff]
Cylon Detected Success
C-Inlet temp 32C
UEA platform with 3670016 Kbytes of main memory
Maximum upgrade attempts exceeded, continuing with old Rommon...
Located IOS-3.18.8aSP/packages.conf
What problem should be the source of the output shown:
Failed to upgrade ROMMON?
7 Replies 7
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/routers/asr903/upgrade/guide/b-upgrade-3x-16x-asr900/m-upgrade-rommon-rsp-asr900.html#Cisco_Task_in_List_GUI.dita_f4b5ec41-239f-45af-a1c8-15c8f3862e13 , following Steps 2 and Steps 3 accordingly the pkg file must be in root-directory of bootflash. Try accordingly and or follow exact command sequence.
 M.
Is it possible then that the reported error is due to the .pkg file not being directly in the bootflash: but in the bootflsh:IOS-3.18.8aSP/ directory?
And referring to the command, it must be applied:
upgrade rom-monitor filename bootflash:asr900_15_6_48r_s_rommon.pkgall
instead of:
upgrade rom-monitor filename bootflash:asr900_15_6_48r_s_rommon.pkg all
- Just put the pkg file in the root directory of bootflash. The pkgall is a
typo, there needs to be a space indeed.
M.
So the complete output would be:
#upgrade rom-monitor filename asr900_15_6_48r_s_rommon.pkg all
right?
Use bootflash:asr.... as filename .
M.
Thank you for your help.
I will do it this way.
I did it this way and the problem continued.
Same output:
