Problem in router 2900
     Hi all,
   we have a cisco 2900 router ,in which one interface is connected to internet ISP and another interface is connected to LAN .
Till morning everything is working fine ,but from afternoon internet is not working .i checked with ISP they said no problem with their end .so i logged into router and do some troubleshoot .
I am not able to ping my outside interface ip from my router iteself . The outside interface is a multilink interface which is formed by bundling two serial interface's
So need help to solve this .
daniel.dib
Level 7
Level 7
Are you saying that you are trying to ping the interface from the router itself? That does not always work.
Which encapsulation are you running? Can you post relevant configs.
Nothing in the logs that indicate that something happened at that point of time? No changes done at that time?
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
Since the original post tells us that "The outside interface is a multilink interface which is formed by bundling two serial interface's"  it is most likely that the encapsulation is ppp. But it would be helpful if the original poster would verify this. To troubleshoot this issue it would be a good place to start if the original poster would post the output of show interface for both the physical serial interfaces and the multilink interface. It would also be good information to have if the original poster would tell us whether he is able to ping the address of the ISP router on this connection.
Rick
Rick
output of  "show interface" command....
Router-3600#show int
Router-3600#show interfaces s0/0/0
Serial0/0/0 is up, line protocol is up
  Hardware is WIC MBRD Serial
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open, multilink Open
  Link is a member of Multilink bundle Multilink1, loopback not set
  Keepalive set (10 sec)
  Last input 00:21:03, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:42:14
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
  Queueing strategy: weighted fair  [suspended, using FIFO]
  FIFO output queue 0/40, 4 drops
  5 minute output rate 1000 bits/sec, 2 packets/sec
     511 packets input, 9474 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     190 runts, 0 giants, 0 throttles
     910 input errors, 516 CRC, 0 frame, 0 overrun, 0 ignored, 204 abort
     4785 packets output, 282172 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     1 unknown protocol drops
     8 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
--More--
Router-3600#show interfaces s0/0/1
Serial0/0/1 is up, line protocol is up
  Last input 00:21:16, output 00:00:07, output hang never
  Last clearing of "show interface" counters 00:42:28
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 17
  FIFO output queue 0/40, 17 drops
     516 packets input, 9448 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     4903 packets output, 288801 bytes, 0 underruns
     0 unknown protocol drops
     6 carrier transitions
--More--
Router-3600#
Router-3600#show interfaces multilink 1
Multilink1 is up, line protocol is up
  Hardware is multilink group interface
  Internet address is 218.248.18.113/30
  MTU 1500 bytes, BW 3088 Kbit/sec, DLY 20000 usec,
  Stopped: CDPCP
  Open: IPCP, loopback not set
  DTR is pulsed for 2 seconds on reset
  Last input 00:21:53, output never, output hang never
  Last clearing of "show interface" counters 00:43:08
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 3 packets/sec
     31 packets input, 2634 bytes, 0 no buffer
     8777 packets output, 564958 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 carrier transitions
Router-3600#
The interface is up and there have been packets received both inbound and outbound. The bundle is up and LCP is open. IPCP is open as well so it seems that PPP negotiation is working.
Can you ping 218.248.18.114? What happens if you try to ping/traceroute something like 8.8.8.8? What configuration do you have PPP?
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
