problem in routing natted traffic between vrf and global
tiwang
Level 3
Level 3
hi out there
I have a - probably simple - problem - I try to use a common internet-breakout for customers with overlapping ip's so I have a lab running where I have 3 vrf's - with the same ip range - which i do a static inside nat to a individual ip range pr vrf - and this looks also fine - the traffic is natted onto the correct ip and send out - but I cannot get the traffic returned from global to the individual vrf's - in global I haven't got a route for each natted Network - how do I get the traffic returned to the correct vrf's?
vrf definition dk10
 rd 65400:10
 address-family ipv4
 exit-address-family
vrf definition dk20
 rd 65400:20
 address-family ipv4
 exit-address-family
vrf definition dk30
 rd 65400:30
 address-family ipv4
 exit-address-family
interface FastEthernet0/0.1
 encapsulation dot1Q 10
 vrf forwarding dk10
 ip address 100.112.10.1 255.255.255.0
interface FastEthernet0/0.2
 encapsulation dot1Q 20
 vrf forwarding dk20
 ip address 100.112.20.1 255.255.255.0
interface FastEthernet0/0.3
 encapsulation dot1Q 30
 vrf forwarding dk30
 ip address 100.112.30.1 255.255.255.0
interface FastEthernet0/1
 ip address 100.112.0.2 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static network 172.22.16.0 100.112.1.0 /24 vrf dk10 extendable match-in-vrf
ip nat inside source static network 172.22.16.0 100.112.2.0 /24 vrf dk20 extendable match-in-vrf
ip nat inside source static network 172.22.16.0 100.112.3.0 /24 vrf dk30 extendable match-in-vrf
ip route 0.0.0.0 0.0.0.0 100.112.0.1
and for dk10 have I then added this - but it does only partly Work - I don't get the traffic back:
ip route 100.112.1.0 255.255.255.0 FastEthernet0/0.1
ip route vrf dk10 0.0.0.0 0.0.0.0 100.112.0.1 global
R0#ping vrf dk10 100.112.0.1 so lo 10
Sending 5, 100-byte ICMP Echos to 100.112.0.1, timeout is 2 seconds:
Packet sent with a source address of 172.22.16.1
*Dec 12 13:49:45.175: NAT: s=172.22.16.1->100.112.1.1, d=100.112.0.1 [95].
*Dec 12 13:49:47.175: NAT: s=172.22.16.1->100.112.1.1, d=100.112.0.1 [96].
*Dec 12 13:49:49.175: NAT: s=172.22.16.1->100.112.1.1, d=100.112.0.1 [97].
*Dec 12 13:49:51.175: NAT: s=172.22.16.1->100.112.1.1, d=100.112.0.1 [98].
*Dec 12 13:49:53.175: NAT: s=172.22.16.1->100.112.1.1, d=100.112.0.1 [99].
Success rate is 0 percent (0/5)
R0#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
icmp 100.112.1.1:18    172.22.16.1:18     100.112.0.1:18     100.112.0.1:18
icmp 100.112.1.1:19    172.22.16.1:19     100.112.0.1:19     100.112.0.1:19
probably a simple trick which is needed - but which?
br /ti
5 Replies 5
You need to redirect the return traffic to the proper VRF.
Something like this
access-list 101 permit ip any 100.112.10.0 0.0.0.255 [to match return traffic. You may change its source]
access-list 102 permit ip any 100.112.20.0 0.0.0.255
access-list 103 permit ip any 100.112.30.0 0.0.0.255
route-map to-vrf permit 10
 match ip address 101
 set vrf dk10
route-map to-vrf permit 20
 match ip address 102
 set vrf dk20
route-map to-vrf permit 30
 match ip address 103
 set vrf dk30
 ip policy route-map to-vrf
ip nat outside
Hope it helps,
Masoud
hi Again
Thanks for the suggestion - looked at it was just the solution - but - I cannot get it to Work - see here
(deb ip nat detailed, deb ip policy and deb ip icmp)
*Dec 12 20:01:22.351: NAT: i: icmp (172.22.16.1, 10) -> (100.112.0.1, 10) [54]
*Dec 12 20:01:22.351: NAT: s=172.22.16.1->100.112.1.1, d=100.112.0.1 [54]
*Dec 12 20:01:22.371: IP: s=100.112.0.1 (FastEthernet0/1), d=100.112.1.1, len 100, FIB policy match
*Dec 12 20:01:22.371: IP: s=100.112.0.1 (FastEthernet0/1), d=100.112.1.1, len 100, PBR Counted
*Dec 12 20:01:22.371: IP: s=100.112.0.1 (FastEthernet0/1), d=100.112.1.1, len 100, FIB policy routed set vrf
*Dec 12 20:01:22.371: IP: s=100.112.0.1 (FastEthernet0/1), d=100.112.1.1, len 100, FIB policy routed set vrf.
R0#sh ip cef vrf dk10
Prefix               Next Hop             Interface
0.0.0.0/0            100.112.0.1          FastEthernet0/1
0.0.0.0/8            drop
0.0.0.0/32           receive
100.112.1.0/24       receive
100.112.10.0/24      attached             FastEthernet0/0.1
100.112.10.0/32      receive              FastEthernet0/0.1
100.112.10.1/32      receive              FastEthernet0/0.1
100.112.10.255/32    receive              FastEthernet0/0.1
127.0.0.0/8          drop
172.22.16.1/32       receive              Loopback10
224.0.0.0/4          drop
224.0.0.0/24         receive
240.0.0.0/4          drop
255.255.255.255/32   receive
R0#
It should work.
Configure an overload NAT and test again
Ip nat inside source list 101 interface  FastEthernet0/1 overload
Ping from a client connected to vlan 10
Please share your last configuration.
here is the output from the problematic router - currently the nat statement for vrf dk10 got removed - but the result is the same for the rest
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.12.12 20:44:13 =~=~=~=~=~=~=~=~=~=~=~=
R0#sh run
Building configuration...
Current configuration : 2845 bytes
! Last configuration change at 20:42:02 UTC Sat Dec 12 2015
upgrade fpd auto
version 15.2
hostname R0
boot-start-marker
boot-end-marker
vrf definition dk10
 rd 65400:10
 address-family ipv4
 exit-address-family
vrf definition dk20
 rd 65400:20
 address-family ipv4
 exit-address-family
vrf definition dk30
 rd 65400:30
 address-family ipv4
 exit-address-family
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
redundancy
ip tcp synwait-time 5
interface Loopback10
 vrf forwarding dk10
 ip address 172.22.16.1 255.255.255.255
interface Loopback20
 vrf forwarding dk20
interface Loopback30
 vrf forwarding dk30
 no ip address
 duplex auto
 speed auto
 vrf forwarding dk10
 vrf forwarding dk20
 vrf forwarding dk30
 ip nat outside
 duplex auto
 speed auto
no ip http server
ip route vrf dk20 0.0.0.0 0.0.0.0 FastEthernet0/1 100.112.0.1
ip route vrf dk30 0.0.0.0 0.0.0.0 FastEthernet0/1 100.112.0.1
access-list 101 permit ip any 100.112.1.0 0.0.0.255
access-list 102 permit ip any 100.112.2.0 0.0.0.255
access-list 103 permit ip any 100.112.3.0 0.0.0.255
no cdp log mismatch duplex
 set vrf dk10
 set vrf dk20
 set vrf dk30
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
 transport input all
end
R0#
and here is a drawing of the topology
Problem is with your NAT.
Change NAT to the below configuration. Remove those interface loopbacks on this router.
Test ping from R1. Traffic must passes both inside and outside(NAT) in order for NAT to work.
ip nat pool my-ip-10 100.112.0.3 100.112.0.3  prefix-length 24
ip nat pool my-ip-20 100.112.0.4 100.112.0.4 prefix-length 24
ip nat inside source list 10 pool my-ip-10 overload
ip nat inside source list 20 pool my-ip-20 overload
access-list 10 permit 100.112.10.0 0.0.0.255
[Add hosts behind R1 to access-list 10]
access-list 20 permit 100.112.20.0 0.0.0.255
[Add hosts behind R2 to access-list 20]
for static NAT,
ip nat inside source 100.112.10.5 100.112.0.5 vrf dk10
Make sure traffic is allowed on ASA. Test this configuration and then share the last configuration if you have problem again.
Masoud
